Results 1 to 11 of 11
    Senior Member Two Rings tomahawk297's Avatar
    Jul 25 2014
    Mississippi
    Angry Screaming noise persists after turbo replacement.....
    So after replacing a ton of things the whistling noise I was trying to fix is still there. In the video below you can hear the sound, can hear it really well if you use headphone.
    List of what I replaced in the past week hoping to fix the sound:
    -Professionally rebuilt turbo and manifold
    -new PCV hoses
    -new turbo oil return line
    -new N75 valve
    -new crankcase breather vent valve hose
    -DV replaced 2 months ago
    Here is the video of the sound:
    https://youtu.be/ZVO8ttVBxhQ
    Jun 17 2013
    jersey city nj
    Sounds like a boast leak from a hose
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    how many miles were on the turbo before it was rebuilt?
    any codes? before or after?
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Jul 25 2014
    Mississippi
    Quote Originally Posted by thenofjboy View Post
    150k. And no codes at all I tried for a month for it to throw a code but after driving it that long without codes I just started replacing stuff and none of the replacements fixed the issue.
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    How did you scan it? You needed to run logs and/or do a scan with a vagcom cable. Soft codes can also be there that could possibly show you the way. But I agree it sounds like a boost leak.
    What ever makes sense go with the opposite and you got it
    Jul 25 2014
    Mississippi
    Quote Originally Posted by Biged243 View Post
    Last month I was driving it and had my mechanic friend with a vagcom scan for codes every now and then, and nothing ever came up. Where should I start looking for boost leaks at? I'll take it back over to my friends shop and see if he can get any codes yet.
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    Have you replaced the pcv valve, or just the hoses? For a quick check disconnect the hose at the intake manifold that runs to your pcv. Try to blow into the hose toward the pcv valve. If you can you have found your problem.
    2018 A5 S-Line Manual
    Jul 25 2014
    Mississippi
    Quote Originally Posted by konarider94 View Post
    PCV valve replaced about 6 months ago, I took it off last week and cleaned it out and it makes the normal working sound when I shake it up and down. I just tried the test and i can't blow through.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by tomahawk297 View Post
    http://www.audizine.com/forum/showth...oost-leak-test
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Quote Originally Posted by vce1232000 View Post
    Yes it does
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    Any luck with this?
