Originally Posted by
R490
Noticed a strange issue earlier......
I took a half hour drive and the coolant temp gauge barely peaked over zero, same drive on the way back and the coolant temp gauge was in the middle in not all that long.
How long does it normally take in 40 degree weather for the needle to move at all, and what could be going on right now? I scanned it for codes, nothing came up.
Any ideas?
I would bet that your coolant temperature sensor is acting up. Are your valve cover gaskets and/or passenger's side camshaft tensioner leaking oil? Usually the oil leaking onto the CTS causes the sensor to fail.
By the way, your car looks like the twin of mine. Mine is green with the same wheels too.
icutrauma1
Yeah mine is taking longer to heat up around NOVA as well. When I turn the heat on with the fan on full blast then the coolant temp goes back down a little bit. If I turn the fan down to one or two bars then the coolant temperature goes back up to the middle.
I have a CTS and oil pressure switch to throw in but I haven't done it yet.
