Results 1 to 30 of 30
    Sep 20 2015
    Los Angeles, CA
    Where can I get a freeze plug for passenger head?
    The last part I need for this ehad swap is the freeze plug that sits behind the cam cover on the front of the head on the passenger side.
    Please let me know so I can button this thing up finally.
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    I would try the dealer of you want OEM. Otherwise, check the diameter with a micrometer and just get a generic freeze plug that matches up.
    Stock engine with some rods tossed in. 11.25@132mph.
    Veteran Member Three Rings Kenrevo's Avatar
    Aug 05 2013
    MA
    ETKA has it as N0119082. They have 28.00 in the remarks column so I assume its 28mm
    '01.5 S4 F21 on meth -- DD
    '05 Touareg V8, loaded
    '00 A4 1.8t Avant SOLD
    '99.5 A4 2.8l 30v QMS SOLD
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Umm, that looks like a driver side head to me
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Sep 20 2015
    Los Angeles, CA
    Quote Originally Posted by zillarob View Post
    How so?
    Nov 16 2010
    WetSide, WA
    It would have the engine code stamped on it by the lift hole at the top right of pic
    That plug should already be there, I think I can see where the oring was from the crossover pipe.
    You can use them on either side, but there are a few things you need to do.
    What work did you do recently?
    Sep 20 2015
    Los Angeles, CA
    Valves were bent, so I got this head from a friend.
    New head gasket is all the work so far. Setting the chain links now.
    What needs to happen for it to work properly?
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    Well on the back side you might have a plugged end that should be open to the water pipe as stated above.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Sep 20 2015
    Los Angeles, CA
    Quote Originally Posted by slow ride View Post
    The coolant pope on the rear is mounted to the head with both bolts. Are you saying that hole may be plugged?
    It looks like the bolt pattern in the pic above wouldn't line up with the coolant pipe?
    Sep 11 2009
    NE
    That's driver side head. Which is fine, but as mentioned above, you need to unplug the coolant port on the back of it, put freeze plug in (which you already determined to be the case), verify that you don't have EGR ports open (now that would make for a nasty surprise) if you don't need them for your engine combo and generally see if nothing else is not missed ....
    Aug 24 2014
    Newport Beach, CA
    This is the plug you need, they just slide in with little force.
    https://www.ecstuning.com/Audi-B5_S4...Engine/ES3181/
    2024 M3 Comp xDrive
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    Quote Originally Posted by christianb5s4 View Post
    i dont know if you mixed up the links, but that is most certainly NOT the plug he needs.
    2000 Achat S4
    Sep 20 2015
    Los Angeles, CA
    Quote Originally Posted by Kenrevo View Post
    ETKA? Do you have a link to where I can buy?
    Aug 05 2013
    MA
    Quote Originally Posted by K04andmeth View Post
    ETKA is the Audi/ VW part program. I would go to the dealer since it didn't look like many places were selling them online.
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    N0119082 is the old part the new part number is N0119085. You can get these at the dealership or online. ECSTUNING sells them for like $1.52
    https://www.ecstuning.com/ES466004/
    Nov 16 2010
    WetSide, WA
    Dont forget the shipping, so prob about $20
    Sep 20 2015
    Los Angeles, CA
    Heh.
    *walks to Audi of Stevens Creek*
    Oct 26 2011
    CA
    Heh.
    Oh, you live in the Bay Area nice. What's your setup K04 and meth?
    Sep 20 2015
    Los Angeles, CA
    Quote Originally Posted by julex View Post
    OK, so I got this straight I need to do the following:
    - Insert freeze plug in the front of the block
    - Check rear coolant channel to make sure there is NOT a freeze plug in there. If there is, remove it
    - Check EGR valves to make sure they are closed
    I have no idea what the EGR valves are or how to check for open/closed.
    Any advice is appreciated.
    Nov 16 2010
    WetSide, WA
    Not EGR, SAI (secondary air injection) ports.
    Its this one here with the ball pounded in the hole.
    And unfortunately, if that head had sai, the hole you need to plug is now behind the timing cover
    Sep 11 2009
    NE
    That would definitely do for a nice mystery ruckus!
    Sep 20 2015
    Los Angeles, CA
    The cams (and covers) are not fixed in place yet, just sitting there, so I can check when I get home.
    Is there a possibility that the head did not have this SAI at all?
    If it does, is there a ball on the rear that I need to remove as well?
    Nov 16 2010
    WetSide, WA
    Coin toss as to whether the new head is already plugged or not.
    If you car has sai, and for some stupid reason you wanted to keep it, then you would need to unplug it on the back.
    Going to take dynamite to get that ball out though.
    They make block-off plates, but dont think you will be able to do it that way because of the timing cover.
    That one in the pic is a 2.8 head I plugged a long time ago. I keep stupid shit like the balls out of old wheel bearings so I just pounded one in and staked it like they do at the factory.
    Other options might be another small freeze plug, or pipe plug that will thread in there flush.
    Sep 20 2015
    Los Angeles, CA
    So theres a possibility that this head doesn't have this SAI opening, and another possibility that the car never had it?
    Nov 16 2010
    WetSide, WA
    Yup, flip a coin. Or just take a look at the thing
    Regardless of whether or not the head or your car are setup for it, make sure the hole is plugged and get rid of everything associated with sai if need be.
    Sep 20 2015
    Los Angeles, CA
    Think I dodged a bullet on this one.
    Both front holes are plugged, as well as rear holes.
    Drivers head:
    Passenger head:
    Sooooo I only need to worry about replacing the front plug, and making sure there isn't one in the rear, where the coolant tube goes, correct?
    Nov 16 2010
    WetSide, WA
    You got it.
    Sep 20 2015
    Los Angeles, CA
    Picked up the plug. How are these things inserted into the block?
    Piece of wood about the ID of the plug and a mallet?
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    Put it in the freezer, pop it in
    Sep 20 2015
    Los Angeles, CA
    Quote Originally Posted by aysix View Post
    Freezer overnight, spare piece of wood, hammer. Got it installed in about 3 smacks.
    Boom!
    Thanks for all the help fellas!
    Onto the timing job...
