Results 1 to 12 of 12
    Veteran Member Three Rings KMEL65STANG's Avatar
    Mar 15 2009
    Washyourrhand's Imola B5 S4 Stage 1,2,3
    HAYWARD, CA
    Thoughts before I rebuild with new turbos!
    Problem: No Boost, No CEL and boost gauge reads about -10 at idle.
    1st thought: Really bad boost leak
    Tried:
    1.Multiple boos leak tests ( holds boost every time, could not find and leak)
    2.Replace n75 with MBC, no change.
    3. Switched ECU's (for tune), no change.
    4. Tested DV's, Holds evertime.
    5. Found WG actuator a bit loose, tightened (so doors stay shut), no change.
    The car smokes (not hella) due to bad valve seals. On test drives, I no longer hear turbos spooling.
    2nd thought: New build
    Which I'm already planning, but I hate to move along without learning how to find the root cause. Does anyone have any knowledge on other areas I could look at to learn what my actual problem is? TIA
    2002 B5 S4 w/ stage 3 driver!
    Aug 24 2014
    Newport Beach, CA
    Does your car smoke at all times? Or only after you've been driving in vacuum for a while? Have you checked for a leaking valve cover gasket? That could cause a decent boost/vac leak since the heads are pressurized under boost and draw vacuum when not in boost.
    2024 M3 Comp xDrive
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Compression test?
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    -10in/hg? That is a mechanical issue unless your gauge is waaaaaaay off.
    Does the car run like total crap?
    Timing belt done recently and then magically no boost?
    Mar 15 2009
    HAYWARD, CA
    Quote Originally Posted by christianb5s4 View Post
    Smokes at idle all the time (now), but not excessively. Have yet to check valve covers. I'll check that this weekend.
    Mar 15 2009
    HAYWARD, CA
    Quote Originally Posted by MetalMan View Post
    Compression test?
    Haven't done that either, but it idles fine and accelerates well. Doesn't feel like any power loss other than no boost.
    Mar 15 2009
    HAYWARD, CA
    Quote Originally Posted by Zba View Post
    No, car runs fine. it use to hold at -20 consistantly. Timing was done about 15k ago. recently did a tune for about 24psi and ran very well until I took it to the track.
    Mar 18 2010
    Ottawa
    I had the same issue. Found out that one of the turbos parted ways with a turbine fin. Car would run fine, idle fine, just never go into boost.
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    How does it accelerate well without any boost?
    Mar 15 2009
    HAYWARD, CA
    Quote Originally Posted by Royal769sr View Post
    Sorry, I meant it does not build boost as usual. On WOT , it builds up to about 2psi. max. So there's still a little vac. As far as accelerating well, It accels like a normal V6 without boost. No stutter or hesitation what so ever.
    May 22 2013
    Las Vegas, NV
    Ohh ok. I got ya
    Sent from my SGH-M919 using Tapatalk
    Mar 15 2009
    HAYWARD, CA
    Quote Originally Posted by Ribbie View Post
    This is what I was thinking as well.
