Results 1 to 23 of 23
    Veteran Member Four Rings klrider44's Avatar
    Aug 20 2014
    Doylestown PA
    Boost leak test.
    Pretty sure I have a boost leak and wanted to make a leak tester as seen in a4mods. First off does anyone know what size pvc would slip inside of the intake pipe. Also I have a block off plate instead of the OEM pcv valve. Will the pressure test work with the plate? Having the block off plate does that mean I just don't have to block off the pcv valve?
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by klrider44 View Post
    Here is a list:
    -90 degree 2" elbow
    -2" PVC cap slip
    -Some kind of silicone sealant (I used gasket sealant and holds up fine)
    -Stainless steel 3" x4" hose clamp
    I also installed a Schrader valve on it to hookup a tire pump to it. But you may want a different fitting depending on what you plan on using
    The 2" PVC elbow will clamp well to the hose accordion hose.
    Aug 20 2014
    Doylestown PA
    Okay I made the pvc test piece and pumped some air in but couldn't hear a leak. My boost gauge only shows like 4-6hg of vacuum. I would have though that with such low vacuum the leak would be obvious but I couldn't hear any leak. Could the block off plate be affecting this test?
    Nov 16 2006
    Skokie, IL
    Why would it show vacuum when you are pumping air into the system?
    Aug 20 2014
    Doylestown PA
    Quote Originally Posted by Sanjman View Post
    I meant I only show 4-6hg of vacuum when the car is running at idle, which leads me to believe I have a boost leak. When I did the test the car was off obviously, but didn't hear a leak. I was wondering if my block off plate would be affecting the test at all.
    Feb 16 2015
    I finally got around to doing a quick boost leak test this weekend and the only place I noticed was a small leak between the intake manifold and the PCV breather hose. Is this normal/ok? I replaced it recently due to cracking the old one during my carbon cleanout.
    2005.5 Dolphin Grey A4 Avant 2.0T Tip / Premium / Lighting / Cold Weather / Sport
    RAI K0R-GT / JHM K04 Tune / 034 HFC -> B7 S4 CB/ ST Coilovers / Hyperco 8" 750 Lb / 034 RSB / 18Z / 15% Tint / S-Line Paddle MFSW / 034 St M and T Mounts / GEN II RNSE
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    I would check for a vacuum leak
    Aug 24 2014
    Southern Tier Upstate NY
    Quote Originally Posted by gonemtbiking View Post
    That's exactly where mine is leaking. I replaced that hose and it still leaks...
    Sorry I don't have a solution or advice; just wanted to chime in and say you're not alone. Hopefully someone has some insight for both of us.
    2006 B7 A4 2.0T Quattro | JHM TP, "Y" Downpipe, JHM/FI B6-S4 Catback | JHM Stage 2: 93 Oct | JHM HPFP Upgrade | GFB DV+ | 034 Rear Sway Bar w/ 034 End Links
    Feb 16 2015
    Quote Originally Posted by Chronotorious View Post
    The one thing I was thinking about trying is cleaning the inside of port on the manifold where the o-ring seals. Might be grimy not letting the o-ring seal properly.
    Aug 20 2014
    Doylestown PA
    Quote Originally Posted by Jake@JHM View Post
    I will be getting a smoke test done on Friday. Hopefully my leak will be fixed then. Jake I still have to send you guys my last set of logs, gotta fix this damn leak.
    Aug 31 2011
    Lathrop
    No worries, whenever you get to it
    Aug 20 2014
    Doylestown PA
    Is there a way I can check vacuum/boost via vagcom?i I have access to a cable and want to double check my boost gauge reading. I think my boost gauge is off.
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Yes, but you'll have to convert the number. The measuring block? Check your favorite search engine.
    Nov 16 2006
    Skokie, IL
    Yes you can even use OBD-II I believe, or at least my torque app + Bluetooth dongle supports it.
    Aug 20 2014
    Doylestown PA
    What app is that? I have dash command and it has always been way off.
    Nov 16 2006
    Skokie, IL
    It's called Torque, most intuitive app for my our phones. If you have the iPhone you need the wifi version of the ELF Bluetooth dongle. Otherwise Bluetooth version is great
    Aug 20 2014
    Doylestown PA
    It must not be available for iPhone, I just checked the App Store. I have the dongle and last time I used the dash command app it said I was spiking at like 35psi which I definitely wasn't lol.
    Mar 19 2014
    Could've swore the torque app doesn't work on theB7? Maybe a different app.
    Nov 16 2006
    Skokie, IL
    Quote Originally Posted by allstock View Post
    It works.... Just not the proprietary can commands for Audi vw
    Jun 26 2008
    Chicago, IL
    soooooo bump... anyone have links to the DIY for leak test? I am really confusssssseddd....
    Take out intake and hook up PCV pipe to the intake tube. but i read that i have to remove the aluminum breather tube... but it doesn't say if I should plug the valve cover or the turbo or both??? also am i supposed to open up or remove anything else? please help!
    Feb 24 2004
    Minneapolis
    Here's how I do it. I tried to make a DIY but the Audizine gods didn't like it I guess. Once you get this made, you put it on the hose coming out of the turbo. That way you don't have to mess with the check valve on the intake. Always remove the oil cap in case some boost pressure leaks into the crankcase and puts pressure on the crank shaft seals.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Jun 26 2008
    Chicago, IL
    Most diys say to go through the intake pipe anyways, but some mention blocking the ports and most are vague about. So you're sure only the oil cap is necessary? I'm assuming you still have the check valve in your breather tube?
    Feb 24 2004
    Minneapolis
    You only have to worry about the check valve if you are testing at the intake pipe to the turbo, thereby pressurizing the turbo and the check valve between the turbo and the valve cover. When you add the pressure at the turbo outlet tube, you are only pressurizing the system as it is designed. No pressure builds up on the turbo or the check valve tube that connects to it.
    I would guess the other guys do it at the hose above the turbo because you don't have to remove the belly pan.
