Results 1 to 11 of 11
    Nov 29 2015
    2001 Allroad
    Texas
    Parting out 2.7t engine APB
    I have a 2001 APB engine that I am parting out.
    The driver side head, passenger side cam shafts, engine block, driver side pistons let me know if you are interested in any of the parts. Or any other parts off this engine. I will take some good and up close pictures to show the condition.
    I have taken the cam shafts off of the passenger side and look perfect. I would expect the driver side cams and crankshaft to be the same.
    I have always put full synthetic oil in the car. The engine has 160,000 on it.
    I am in Houston area. Shipping extra.
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    how much for say 2 coil packs (decent shape) and a couple of the valve cover nuts?
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Junior Member One Ring TehFriedRice's Avatar
    Sep 12 2015
    '10 Evolution SE, 2X: '06 mazdaspeed6, 2X: '03 Vibe GT, '12 Volvo s60, MK3 golf, C5 allroad
    NV
    How much for the crankshaft and one piston to 89005?
    Nov 29 2015
    2001 Allroad
    Texas
    Quote Originally Posted by TehFriedRice View Post
    Crankshaft and 1 piston $120 plus shipping.
    Excuse my ignorance what does 89005 represent?
    If you are interested I will take pictures up close of the crankshaft and send them to you before anything. It may likely be next week before I can take the pictures. I still need to pull it out. I am in the middle of an engine swap. And I need to get this buttoned up.
    Nov 29 2015
    2001 Allroad
    Texas
    Quote Originally Posted by PaperToast View Post
    $25.00 plus shipping
    Nov 29 2015
    2001 Allroad
    Texas
    Quote Originally Posted by tewnick View Post
    Sorry the replacement engine did not come with them so I will be reusing my old ones.
    Sep 12 2015
    NV
    Sorry, I meant shipped to zipcode 89005. How much for just one piston? I just realized I have a 2.8 crank I can use.
    What happened to your engine? One chain snapped?
    Nov 29 2015
    2001 Allroad
    Texas
    Idler pulley bearing went out. Belt got loose. Skipped time. Passenger side head and pistons destroyed.
    One piston ? $40 plus shipping? I am not sure what shipping will be. I will only charge what it costs me.
    Apr 29 2009
    Quadzilla
    Longmont, CO
    no worries, sorted out my misfire issues and as bender would say ,'quadzilla is back baby'
    how about a few of the valve cover nuts?
    discovered a few that are stripped
    Rockin' the Rockies
    Nov 29 2015
    2001 Allroad
    Texas
    I have
    older style intake manifold
    2 tensioner,
    2 sets of cam shafts,
    One crankshaft
    Driver side head.
    Exhaust manifolds,
    K03 turbos in good shape,
    Oil pan,
    After run pump,
    Power steering pump,
    Oil and coolant lines for the turbos,
    Knock sensors,
    Taking offers.
    Feb 15 2016
    Virginia
    How much for the driver side timing belt cover? The one directly behind the fan clutch. Shipped to 23464.
