    Mar 27 2012
    1980 Harley Sportster
    Ocean city, nj
    440cc injectors leaking
    I've been having a rough idle and random misfires for quite some time now. Replaced just about everything in the vacuum system in the last month, it got a little better, but still giving me a hard time. Was spraying some carb cleaner around about a week ago and all injectors but number 2 were leaking/ sucking air at the manifold. Grabbed some new o rings off of ecs tuning and installed. They didn't seem to fill the channel in the injector all the way. They are Bosch 440cc injectors and didn't put any thought into different o rings then stock. It's now leaking on all cylinders. Anyone else ever have this problem, or know where to locate a thicker o ring? Thanks
    Apr 15 2014
    Ottawa/Gatineau Canada
    Semi hijack...
    What is the spec for the stock O Rings?? (dimensions)
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by Luxus Panzer View Post
    Semi hijack...
    Lots of "O" ring information in this thread: Clickly click®
    Mar 27 2012
    Ocean city, nj
    Thanks for the thread link old guy, already saw that and that's where I got my part number to order the last set of o rings, problem seems to be that the channel in the 440cc is a lot thicker. Still leaking like crazy to the point where I had a hard time starting this morning in the cold.
    Mar 27 2012
    Ocean city, nj
    Anymore insight from anyone?
