Results 1 to 17 of 17
    Dec 31 2014
    Conroe, Texas
    Oil drain plug leak question
    2005 3.2 L and I've got a slow, insidious leak from the oil drain plug. I've been looking at either A) Replacing the lower oil pan, or B) Taping and Heli-Coiling it. Anyone have a similar problem/ Solution?
    Thaks a ton
    Jul 17 2011
    Sin City, USA
    Do you know what is causing the leak? Is the oil pan cracked at the plug?
    '09 C6.5 A6
    Dec 31 2014
    Conroe, Texas
    Not sure, after changing the oil it started a slow leak.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Did you change the crush washer? They stipulate to do this each change but I've done about 20 oil changes with the same plug and washer with no issue. I'd start with that. Could also just be some dirt or something between the washer and the pan.
    Dec 31 2014
    Conroe, Texas
    I hadn't thought of that, and I see how that could cause an issue. I'm willing to bet that there is something between the crush washer and the pan.
    Senior Member Three Rings skylinrcr01's Avatar
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Once you resolve the leak, you should look into getting a mightyvac. You can change the oil topside, and since the filter is up there too, you never need to jack the car up. Also never have to remove the drain plug.
    http://i.imgur.com/KPi8p89.jpg
    2004 Mercedes E55 AMG
    2005 A6 Quattro 3.2 (Sold)
    2005 BMW K1200S
    Veteran Member Three Rings Markie93's Avatar
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    I had an oil leak around there too on my 4.2L. I changed the crush washed washer and the leak was gone. since they are only like $1 a piece, I bought like 8 of them and chance it every oil change. no leaks since.
    Feb 06 2013
    CA
    I did away with the whole oil drain plug, crusher, etc...years ago. I purchased and installed this and could not be happier: http://www.qwikvalve.com/
    I can start and finish my oil change in less than 20 mins from start to finish! The hardest part is cleaning up my oil catch pan ;)
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Wow, that's wild!
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Jan 24 2012
    Calgary, Alberta, Canada
    FYI! Straight from the Indys mouth;
    "Audi changed there crush washers recently. I had to put 2 on your drain plug"
    I had a slow oil leak from the pan at the plug after MY most recent oil change and the indy informed me of the new crush washers. I had zero problems up until this - and after he put 2 on it I have not had a leak yet.
    I am 100% confident that this is your issue.
    Dec 31 2014
    Conroe, Texas
    That's music to my ears, two new crush washers it is
    Nov 12 2015
    Oregon
    Quote Originally Posted by sun_dance View Post
    What happens when you hit a speed bump or something?
    My build log
    Feb 06 2013
    CA
    Quote Originally Posted by VinnysS4 View Post
    I've hit speed bumps and no issue whatsoever. Based upon where it's placed and mounted, I'd be more likely to sheer my entire oil pan than have this thing sheer off. My car is lowered and even then I've never had any issues and been running it for years. Like I said, it's probably one of the best mods I've ever done and so convenient form a maintenance perspective...especially after I made an access door in the shield with a piano hinge and some super strong magnets.
    Dec 31 2014
    Conroe, Texas
    Well, installed the new drain plug and crush washers, still have a slow leak. I was looking at the threads in the oil pan and they look like they are stretched out from over torquing. Anyone ever just tap the hole and go from there, or should I just replace the oil pan?
    Established Member Two Rings snokarver's Avatar
    Apr 30 2009
    Was it an OE drain plug? When I got mine, someone had put an aftermarket one in. It leaked. I replaced it with an OE one and the problems went away. The other one had considerably more play in it.
    Dec 31 2014
    Conroe, Texas
    I got a 5 pack of Dorman M14 x 1.50 drain plaugs
    Dec 31 2014
    Conroe, Texas
    Has anyone tried using a self tapping drain plug? If so, did it work?
