Results 1 to 8 of 8
    Established Member Two Rings Attrick07's Avatar
    May 30 2013
    Massachusetts
    Need Set of Headlights for 01 S4
    Looking for set of unmolested headlights in good condition with mounting tabs intact/not cracked. Tired of screwing with my 3 broken tabs and hacked up wiring. Also need to have yellow side markers to pass inspection.
    Thanks
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    I have set of Oem ecodes. They aren't made with yellow side markers so would that still pass inspection? No broken tabs.
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    May 30 2013
    Massachusetts
    Quote Originally Posted by Yuppie View Post
    I wish I could pass with the clear ones, Mass. is pretty strict about having the yellow side markers. I've dealt with it before on other vehicles.
    Jul 20 2014
    Colorado Springs
    Yuppie, how much do you want for your headlights? & any pics?
    Feb 14 2005
    PM sent. I don't want to mess up OP's thread.
    Established Member Two Rings ShooterMcgavin's Avatar
    Feb 26 2015
    Imola B5 S4 Avant
    Colorado Springs
    You've got a PM!
    No regrets, that 's my motto! Well, that and everybody Wang Chung tonight.
    Established Member Two Rings SacS4's Avatar
    Oct 05 2012
    what garage?
    Traverse City, MI
    I have a set I've been running for 2 years. New bulbs and big bright highbeams. Parting out my S4. Northern Michigan part out thread.
    2001 S4
    APR bi-pipe, Bailey DVs, K&N 57i intake w/ Aluminum Heatehield, Vasts Stage 3 clutch w/LWFW, AWE in-vent Boost gauge, APR stg 1+ (93) software flash, 034 aux. Water pump delete, 034 phenolic spacers, 3 different driver front axles !!! Dyno jet (260/277)/Torque Pro OBD (245/340)
    May 30 2013
    Massachusetts
    Thanks for the help guys, was able to locally pick up a set from f4mou5.
