Hoping for some help.
Background info:
The other day i get home from a 30 minute drive. Car is working like it should.
I park facing up a slight hill in my street where i normally do. Car is in 1st gear.As normal.
Next day i go to leave for work and the car wont start. I notice it sounds weird too.
I check for codes and i get a p0685. So i replaced the j271. Codes gone but no fix.
I check for spark. Its fine.
Old guy suggestss i try to check the injectors by spraying them into a bottle.
I put a bottle under each injector, cranked the engine for about 10'seconds and theres about a teaspoon of gas in each bottle now. Seems like the injectors are ok and i assume the coolant temp is being read. I get no dtcs.
Great right? No.
So i was looking at my valves through the ports for the injectors and i realized that theres some kind of issue with the valves cause on the front 2 cylinders have closed jntake valves and there are pools of gas. So at that i take off the valve cover and its confirmed. The cams dont move. When i run the starter. How can that be? The starter is moving the serpentine belt and all the accessories. My timing belt is worn out but in tact at the top end. No missing ribs or anything.
So to see what the deal was, i tried to turn the cam gear by putting a wrench on it. When i turn it it compresses the cam chain tensioner but when its all the way flat the cams wont move. the intake cam is completely frozen from what i can tell without taking the whole head apart.
So how do i proceed? I assume this means im going to be doing a timing belt job and trying to rebuild the head?
Also how does this happen? Could Parking on a (very) slight uphill have caused the cams to go backwards and damage something?
Considering im leaving my job in a few days, this is literally the worst possible timing and i need the cheapest possible solution which means getting nice and dirty and cold.
