Hey Audizine, I have a bunch of codes here I need some help with. Just got a misfire a few minutes ago but I know how to correct it. Though I am unsure what the rest of these codes indicate.
If you guys/gals could give me a hand it would be much appreciated.
P0301 - Cylinder 1 Misfire Detected (Either spark plug or coil pack)
Engine: (I have no idea what these are)
P0A54 - Drive Motor "A" Current Sensor Circuit High
P0FD6
P0FD3
Airbags: (I have the airbag harness disconnected but don't see how these two codes have to do with the airbag)
9437210 - Actuator Distribution Valve Defrost or Dashboard Vents right (V205)
9437466 - Throttle Position Actuator (V60)
BTW I used Carista to pull these codes if that matters at all. Thanks again.
