Results 1 to 3 of 3
    Active Member Two Rings AudiTony25's Avatar
    Jun 09 2014
    Right here
    Thud sound when accelerating aggressively
    I have a B8 with 85k mi. Only mod is an APR tune and 034 trans mount I put on about 15k mi ago. When I accelerate hard in 1st, 2nd, or 3rd, I get a loud thud from the front of the car almost like behind the dash in the engine compartment. It's a P+, replaced ignition coils and plugs a while ago, but I don't think that's the cause. I don't have sport suspension and to my knowledge I still have stock shocks and struts. I always let the car warm up too.
    Tried googling around a bit- nothin. Anyone else ever experience this? What could the issue be. I doubt the trans mount has anything to do with it but I'm no expert, I've only owned the car almost 3 years.
    Appreciate any ideas/insight
    APR Tune Stage 1, Afe, R8 Plugs and Coils, Michelin Pilot Super Sport Summer 19s on S5 Split-5 spokes. 034 Trans Mount
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Motor mount(s).
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Check the 034 mount. If you didn't use loctite, the bolts will work themselves loose and cause drivetrain slop.
    If not that, it's what he ^ said.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
