Results 1 to 3 of 3
    Senior Member Three Rings mfdk's Avatar
    Jul 25 2012
    A4 B5 V6 2.8l
    Fort Mill, SC
    Turbo Oil & Coolant line to the Block metal Washers..!
    The oil and coolant lines coming off the turbo that connect to the Engine block both contains two metal washers for each line, my question is..should one washer go in front of the line and one after the line or do both go together either side of the coolant or oil line.... Someone asked me about this question and i cant remember last time i did the work on my car.
    If i remember correctly right order should be..
    Starting from the block: Washer to the block --- oil/coolant Line --- washer on top of the line --- then screw/bolt....!
    Cheers
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    The line is in the middle, and each washer goes on both sides of the line. so washer, line, washer.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Jul 25 2012
    A4 B5 V6 2.8l
    Fort Mill, SC
    Quote Originally Posted by Denio24 View Post
    Great, i wanted to make sure i was correct before i gave someone else the wrong info.
    Thanks a lot.
