Results 1 to 40 of 80
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Thumbs up JHM Supercharger Kit (Stage 1) for the B7-RS4 is NOW AVAILABLE!!
    Introducing the JHMotorsports Stage 1 B7-RS4 Supercharger Kit!!!
    The JHM Stage 1 Supercharger is hands down the most cost effective supercharger solution for the B7-RS4. With common bolt-ons and supporting hardware, we have repeatably achieved mid to high 11 second quarter mile runs, with 117-118MPH trap speeds!! With performance like that, your seemingly unsuspecting four-door German sedan becomes a definite force to be reckoned with.
    The JHM Stage 1 Supercharger Kit is the foundation for the different power levels available for the B7-RS4. With the addition of a smaller pulley, an intercooler, fueling upgrades, or even a built motor along with our software upgrade, you can build off of the Stage 1 kit to meet your power output needs. This Stage 1 Kit features the same supercharger head unit that was on our in-house, record setting 2007 B7-RS4 4.2L FSI that ran an incredible 10.7 second quarter mile at 130 mph. That was at full weight, a complete interior, a complete exhaust system, and street tires!
    FEATURES AND SPECIFICATIONS
    Our JHM Stage 1 Supercharger Kit for the B7-RS4 will make 80 to 100 wheel horsepower (WHP) over your car's current configuration. Your current modifications, the dynamometer (dyno) used, temperature, elevation, and octane of gas will all effect the exact amount of power gains.
    Our Supercharger Kit features a Vortech V3 Si Centrifugal Supercharger Head Unit that is good for up to 800 horsepower! (Unchecked, this amount of power would be too much for a stock RS4 motor. Through our extensive development and testing process, we were able to limit the output of the supercharger to levels safe for the stock motor through hardware and tuning.) The V3 Si blower is a self-contained unit featuring quiet, helical cut gears. The only time you hear noise from the blower is at idle and low speeds. At wide open throttle, you hear nothing but the raw power coming from your JHM Supercharged RS4.
    The JHM Stage 1 Supercharger Kit also includes our JHM Supercharger Mounting Brackets that were designed and are made in-house. These brackets are made from reinforced steel, laser cut, and then powder coated black for a clean installation.
    In order to insure the longevity and durability of the belt and pulleys on the RS4, we upgraded the OEM belt and pulleys to a 6-rib system with our JHM 6-Rib Accessory Belt Conversion Kit which includes our Automatic Tensioner Upgrade. This Conversion Kit features 3 JHM Supercharger Kit specific pulleys including an Alternator Pulley, a precision zero-balanced Crank Pulley, and a Supercharger Pulley good for 5 to 7 pounds of boost (exact boost levels will vary depending on your exhaust system, other modifications, and environmental factors).
    Due to the compact engine bay of the V8 RS4, we had to locate the Vortech Supercharger Head Unit off of the passenger side of the motor, below the headlight. We created a number of different proprietary parts including our JHM Supercharger Kit Silicone Inlet and Outlet Hoses. The Inlet Hose is made from reinforced silicone to prevent collapse under vacuum. The air intake is filtered through a JHM Supercharger Kit specific K&N high-flow, conical air filter.
    We are currently working on JHM Supercharger Kit add-ons that will allow you to use more of the supercharger's power capabilities. Stage 1+ (Intercooled with upgraded fueling and a smaller pulley, safe for stock motors) should be available in Spring of 2016. Stage 2 will require a built motor for engine safety and longevity. Please contact us for more information regarding Stages 1+ and 2 as well as a JHM Built Motor for your B7-RS4.
    PARTS INCLUDED
    - Vortech Centrifugal Supercharger (Good for up to 800 horsepower)
    - JHM Laser Cut Supercharger Mounting Brackets
    - JHM 6-Rib Pulley Upgrade, Accessory Belt Conversion, and Automatic Tensioner Kit with JHM 6-Rib Supercharger Pulley, JHM 6-Rib Alternator Pulley, JHM 6-Rib precision zero-balanced Crank Pulley
    - JHM Inlet Hose, made from Reinforced Silicone
    - JHM Silicone Outlet Hose
    - JHM Crankcase Ventilation System
    - JHM MAF Housing
    - K&N Conical Air Filter
    - JHM Stage 1 Supercharger ECU Tune
    - Spark Plugs, JHM Supercharger Kit Specific based on the boost levels of this
    - JHM A/C Receiver-Drier Relocation Kit including new hoses and JHM Modified A/C Lines for easy, bolt-on fitment
    - All bolts, hardware, clamps, and miscellaneous items required for a complete installation
    Click HERE for more information!
    If you have any questions or would like help placing an order, don't hesitate to give us a call or shoot us an email!
    209-968-0077
    [email protected]
    Jake
    Aug 31 2011
    Lathrop
    Reserved
    Aug 31 2011
    Lathrop
    Reserved
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    That should work just fine with my Touareg... :)
    Aug 31 2011
    Lathrop
    Quote Originally Posted by 430hps4 View Post
    Bring it by and lets find out
    Aug 30 2013
    Townsville
    Congrats guys. Having followed this for quite some time, it's great to see the final product. Also seems like there has been a lot of reliability testing on the kit before being made available to the public, so kudos to that. Will be great to see some more of these kits on the road. Gotta save up the $$$ and get the courage to do the RHD mods to fit it to my Avant here down under :)
    Account Terminated Four Rings Quattrors4's Avatar
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Congrats guys !What are thoes yellow resistors for ?
    Feb 24 2010
    And have never been happier
    Quote Originally Posted by Quattrors4 View Post
    Conga rat guys !What are thoes yellow resistors for ?
    Fog light deletion so that instrument cluster wouldn't report any errors - feel free to correct me on this.
    Aug 31 2011
    Lathrop
    Quote Originally Posted by Caillin View Post
    Thanks! We have the parts for RHD installation as well!
    Thanks man. Those are the fog light resisitors.
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by wednesday View Post
    Why ? Don't tell me you have to delete the fog lights for the kit
    Aug 31 2011
    Lathrop
    Passenger side for stage 1.
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    Plenty of space in the Touareg, no need to bypass the fogs. I can see a discount in my future...
    Aug 31 2011
    Lathrop
    resistors aren't that costly
    Dec 30 2009
    1995 Corrado / 2004 R32
    Vancouver, BC, Canada
    The non-optional fog light delete mod I would imagine no?
    May 04 2007
    Northeast
    Pardon my ignorance, but why does a Stage 1 RS4 run about the same times as a Stage 1 S4? Both high 11's, right?
    Glut / Capristo / Baby Seats
    Aug 31 2011
    Lathrop
    Quote Originally Posted by GrandMarkie View Post
    For a Stage 1 SC S4 to run 11s requires a lot mores supporting hardware than the RS4 does.
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    A bare bones kit could be fun. Sell just the V3 Si, mounting brackets, pulleys/tensioners, and belt... I'll figure out the rest. ;)
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    got to say its a good cheap option to get into a boosted rs4,jake you should post a dyno with before and after result
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Good to see another option officially on the market!
    Now Jake, I assume stage 1+ is a better judge of the stock engine's capabilities? What can we expect from that? Are IATs an issue without the intercooler setup, resulting in the fairly modest power figures? I understand the stock internals can handle a good bit more power than 100whp over stock.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Quote Originally Posted by LINDW4LL View Post
    For how long though?
    Dec 10 2011
    CLT | MKE
    Forever.
    Sent from my iPhone 6 using Tapatalk
    -Hayden
    Jan 31 2013
    '03 Jetta Wagon 1.8T
    DC
    Congrats on making it to market, and thank you for providing a HP estimate! ;-)
    Sent from my Nexus 9 using Tapatalk
    Dec 03 2009
    PNW, Washington
    I thought this was available years ago?
    Apr 01 2015
    Wilmington NC
    So does the 1+ not require fog light delete?
    May 29 2012
    Evergreen, CO
    Quote Originally Posted by Peter1.8t View Post
    That was my exact thought when I saw Jake's first post "introducing" the Stg.1 sc. I thought there were already a number of RS4s around with this mod.
    Dec 10 2011
    CLT | MKE
    Yeah, JHM seems to be slow with their "official" releases. I don't get it.
    -Hayden
    Veteran Member Three Rings OscarMeyer's Avatar
    Oct 01 2010
    VW/AUDI Only
    Burnaby
    It's been available for a while, you just had to call and talk to an actual person, now you can just add it cart and check out? Honestly not a big deal?
    Jake is that Jason driving? Holy quick shifts!
    07 RS4 - Projekt: Pandora
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by OscarMeyer View Post
    They like to make sure that everything is well tested before it is officially released. Great idea to me. More companies should do that too.
    Yes that is Jason driving in certain in car parts of the video. He can row some gears.
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    yould be really nice to see some dyno numbers before and after to see the power and torque curve
    are they scared to show the results or what ?
    Senior Member Two Rings b6dolphins4's Avatar
    Aug 07 2011
    Binghamton,NY / Raleigh, NC
    Are you scared to show REAL time slips?
    2004 DG S4
    Mods:| JHM 93 Tune |JHM Stg 4 Clutch | 034 Light Weight Flywheel | Trexturk Cat less Dp's | Custom 2.5" Non-res Magnaflow CB | K&N Drop-in | 034 MAF hose | Apikol Snub/ Zero Gap Bracket | 034 Trans mount | JHM S.S. | JHM Knob |
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Quote Originally Posted by b6dolphins4 View Post
    not at all but we don't mass produce a blower kit ,and all I'm saying I'm sure people want to see numbers before and after and see the results
    Veteran Member Four Rings FulhamFTW's Avatar
    Jul 11 2010
    STL, MO
    Dude, are you serious? You're the last person to ask anyone for anything. You can try and compare horsepower numbers all day long, but the fact of the matter is, their car is quicker for a fraction of what your kit costs to the general public and is certainly much better tested. Don't get all butthurt now. Take note of how they operate and maybe one day you'll be successful too.
    Veteran Member Four Rings Mistro's Avatar
    Jun 19 2011
    There are plenty of results in the video.
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    Quote Originally Posted by FulhamFTW View Post
    You beat me to it.. It's not enough that he has a horrible reputation for unsubstantiated claims on this forum, he has the balls to come into a JHM product thread, and question them on performance stats.
    Keep tuning that TT setup buddy.. Let us know when you have anything real to show at all.
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Active Member Four Rings EUROSWAGR's Avatar
    Oct 11 2008
    2015 Ford F-150 FX4 (twins) / 2012 Audi Q5 S-line
    East Coast
    Why the fuck is Mario even still part of this forum?
    "Make yourselves sheep and the wolves will eat you." ~ Benjamin Franklin
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    Enough about/from Luigi. Nice vid JHM makes me miss my RS. Very happy you guys are dabbling with b8s now gives me hope.
    2019 QUANTUM GRAY S4
    Stock
    Prev
    2015 SUZUKA GRAYRS5
    2013 SUZUKA GRAY RS5
    2015 MYTHOS BLACK S4
    2008 AVUS RS4
    2004IMOLA YELLOWS4
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    But you are offering to sell your TT conversion - here's what you said on RS246.com...
    Quote Originally Posted by Chargedrs4
    Quote Originally Posted by Darkniters4
    Thanks for clips. Can you a actually do a turbo conversion on the rs4. Who could i contact with regards thereto.
    Many tks
    G
    yes we can a conversion ,you can contact me ill give you all info you need
    Mar 26 2007
    Colorado
    JHM Backs up their products with 1/4 mile times, not Dyno numbers..... Which is how it should be... Dyno's can be manipulated. A 1/4 Mile time can't (unless you scan and edit your slip)
    *Which is why I supported JHM so much with my S4.
    CURRENT:
    2021 Atlas
    Dec 07 2009
    East Coast
    Congrats on an official [overdue as always] release
    Now hurry up and get that B6/7 S4 built motor program streamlined!!!
    Forget the B8, keep the V8!
    Apr 01 2015
    Wilmington NC
    So jake does the 1+ kit need the fog light delete or not?
