Results 1 to 10 of 10
    Veteran Member Four Rings crazexr7's Avatar
    Sep 10 2011
    1998.5 A4 2.8 Quattro, 2001 Porsche Carrera 4, 1968 Cougar XR7
    Bristol, CT
    Pic Request: V6 B5's with THOR skid plates
    Can anyone grab a pic from the driver side of the car that shows how close the skid plate is to the oil pan?
    I put mine on my avant and it's been a long time since I've seen one installed (I had it on my old car). Anyways when I bolted it up it seemed way too close to the front part of the oil pan.
    This is with the front bolts just slightly loose so it would've been even tighter in here were they tightened all the way
    I added a bunch of washers to the front bolts to space the skid plate a little more just to be safe
    Anyone have similar pics of their skid plates without any kind of washers? I think if it ends up being similar I'll probably ditch the washer spacers, because now those are leading me to believe they might cause other issues.
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    Do you have the plastic V6 rear washers they sell? That looks like they're missing.
    I'll try to snap a pic later
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Sep 10 2011
    Bristol, CT
    Quote Originally Posted by bmos View Post
    The rear spacers are just kind of optional for air flow. They won't really help the clearance in the front of the oil pan
    Apr 29 2014
    Maine
    Quote Originally Posted by crazexr7 View Post
    Maybe it's just my poor memory but I think the spacers add clearance as well by pivoting the sheild at the front.
    Dec 23 2009
    Boulder, CO
    You are correct
    Sep 10 2011
    Bristol, CT
    Rear spacers just aren't an option I want to consider. It'll lower the plate more than I am comfortable with. I just can't remember if this was how my skid plate was on my old car. If it is I'll probably leave it alone because I've hit plenty of things and not cracked the pan.
    Jun 30 2008
    Erie, Pennsylvania
    Well, if you don't want to space the plate down, the only other option is to add spacers to move the engine UP.
    I realize this might sound crazy, but I think you'll be surprised.
    Kidding aside, my Thor plate took a HARD hit and did bend it some. If the pan had been touching, I'm not sure it would have made it.
    Sep 10 2011
    Bristol, CT
    I actually went back today and tried something else, 'cause I had my suspicions that the skid plate wasn't pushed all the way forward that it could go. So I pushed it forward a bit after loosening all the bolts, and ditched the front washer/spacers I put in and it looks good now. Still kinda close but I think the clearance is fine.
    Forgive the vertical video.
    And Walky, I should've lifted the engine while I was swapping everything! Ever since I found out someone else did it now it's got me thinking lol
    Nov 07 2010
    South of Heaven
    My 1.8T has a Thor plate and it has the large white spaces on the rear and I have never had an issue. I could not count the times that skid plate has kissed concrete and no bends so far. If it is not the skid plate scraping on something it is the DTS which I high sided twice today on speed bumps and my car is not slammed although it is lowered.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
