Results 1 to 6 of 6
    Mar 15 2015
    Norway
    S4 grill mesh in standard lower grill ("Eddie man mod") - pictures inside
    I recently bought an S4 upper grill from a salvage car, and decided I wanted to have matching mesh in my lower grill.
    Since I got the lower S4 grill, with broken tabs for $12 (!!), I decided it was worth modifying:
    S4 grill vs. standard grill
    Separated from their frames (the S4 grill is actually wider, even though the picture may fool you)
    Cut away these tabs to make it sit flush against the original grill (so you know where to cut)
    Use zip ties and fasten the original grill to the front side of the S4 grill. Make sure to leave approx 3 mm step between the top of the grilles, to get the correct dimensions when cutting away the bottom part
    Use the blade from a big hacksaw, and use the curve of the original grill as a guide when cutting the bottom part. Repeat on the sides, but here you need to make a straight cut, not angled like the bottom part.
    3 of the "hooks" matches between the grilles, but some modification is needed
    Cut away these tabs
    Test fitting
    I attached the grill mesh to the frame by drilling 4mm holes and using machine screws (6 in total)
    Finished product!
    Now I need to improvise on how to attach it back to the car.
    Apr 07 2011
    Wow. Looks really good, nice work.
    Mar 15 2015
    Norway
    Updated with a new photo of the final look.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Clever retro fit of the S4 grill.
    USP CLUB MEMBER #34
    Mar 15 2015
    Norway
    Uploaded photos again for future reference
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Looks Great! I don't think that will work for us usp guys.
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
