Originally Posted by
f4m0u5
Thanks for help. I should have mentioned I got the drive shaft for cheap and to rebuild it with new joints and center bearing will be a total of $300.
Also I did have it diagnosed (but not by an audi specialist) and replaced a billion parts between. I already have upgraded front mount on my rear end.
Also I've tried 2 brand new sets of wheels and tires. One were high-speed blanaced. The next set I just threw on a few months ago are also brand new with brand new tires and road force balance.(the first thing I thought was bent rim or a bad tire when I bought car)
I already replaced a rear wheel bearing also and have upgraded motor/transmission/snub mount and meyle hd controlled arms
My current rear end has the more expensive motul gear fluid in it that was changed out less then a year ago. Is that fluid not good for our cars? I was recommended it by a local vag shop
ZF diffs aren't really known to fail and if it was causing the clunk there would probably be very audible noises, if you drop the exhaust and remove the heat shield it's easy to see if the u joint is bad, I may go that route and if it is have your driveshaft rebuilt if you can afford not having the car and the shop is willing to let you leave it there.
Will also save you labour costs as the shop has to do that work anyway to re and re the driveshaft, the only thing your paying extra for is a quick check of the driveshaft. If a shop tries to fleece you for inspecting and then full price for re and re then it's a good sign to find someone else to do the work.
