Results 1 to 6 of 6
    Dec 03 2015
    Melbourne
    Weird engine noise.
    Hello all,
    I am new to this forum but am a member at ozaudi.com.
    For the past few months I have had a problem with my car.
    The car is a B7 2.0T Quattro, with a carbonio intake, stage 1 revo tune, revised pcv and a bsh diverter set up.
    The symptoms I can describe is when I hit up to about 4000-5000rpm whether I am just revving or going through gear there is a weird noise that's like a wobbly sound. The car would run pretty average once that happens(rough idle) but it then goes away and would come back if done again.
    My mechanic thinks it's a cracked engine mount but a few other people think there's no way the sound could be from a engine mount problem.
    I have attached a video bellow, I'm sure people would be able to tell that there is something wrong.
    Active Member Two Rings SteveA4B7's Avatar
    Jun 16 2015
    South Africa
    You talking about that whining noise, when you leave the throttle and revs come down, right?
    Do you still have the stock catalytic converter installed?
    Dec 03 2015
    Melbourne
    Nah not the whining noise. Put the volume up and listen to 2-4 seconds, it sounds like the engine is over revving but it's no where near red line.
    I have the stock cat.
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Definitely not engine mount related...Have you boost leak tested your car? Sounds like air to me....
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Dec 03 2015
    Melbourne
    It's less noticeable when I put it back to stock but it is still there. I havn't boost leak tested it, what is the best way to diagnose if it's actually a leak and from where it's coming from?
    Dec 19 2012
    Europe
    Quote Originally Posted by vozduk View Post
    Air pressure test...System should hold a certain amount of pressure IIRC...Don't know what the exact PSI is though.
    As well, smoke or dye works good...
