Results 1 to 9 of 9
    Dec 03 2015
    Calgary, AB
    Hardwire Radar Detecto
    Hello everyone, I am trying to hardwire my radar detector. I tried tapping the rearview mirror's power but unfortunately it wouldn't turn on the detector. It would turn on for a second then it would just turn off again and it repeats. I used a volt meter to check and there is 12V going to those wires. Has anyone encountered this issue before? Thanks
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Just start by checking the connections you made. Sounds like there may be a bad connection.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Dec 03 2015
    Calgary, AB
    I made sure those connections were snug and I matched the positive with the red wire and negative with the black wire. There were also a brown and blue wire but I think those are just signal wires as it doesn't give out any power
    Senior Member Two Rings JohnnyUtah787's Avatar
    Oct 03 2015
    Illinois
    2015 Audi S3 - Glacier White, 19" Performance Package, B&O Sound System, LED Lighting Package, Black Optics grille, Black optics fog grilles, Black powder coated OEM exhuast tips, Satin black 19x8 ET45 Neuspeed RSe10 wheels with Continental ContiSportContact 5P tires (summer set-up), OEM 19x8 ET49 double 5-spoke wheels with Pirelli Winter Sottozero 3 tires (winter set-up), 15 mm ECS spacers all around, Emanuelle Design springs, 034 Motorsport dogbone mount insert
    Active Member Two Rings Sandman626's Avatar
    Mar 28 2015
    DE
    Quote Originally Posted by JohnnyUtah787 View Post
    I tried going that route (did it in my B6 Passat no problem) but the fusebox is much harder to reach in this car so I ended up tapping into the mirror.
    I forget if I went into red or brown, but if red is giving you trouble, check if any of the others are supplying power and try those.
    2015 S3 Prestige | Audi Exclusive | Mesh Grille | AWE S-Flo Carbon Intake | APR Turbo Muffler Delete | OEM Sound Enhancing Resonator Delete | Rohana RFX5 Brushed Titanium 19x8.5 +42 | Toyo Proxes 4 Plus 235/35-19
    2016 CBR300R | Candy Orange -- Toy
    Sep 29 2007
    02 S4 /07 S4 / 11 Q5 / 16 S3
    Clarkston, MI
    I connected mine here, make sure you have it pushed all the way in I had mine flake out after I put everything back together and after I pushed the the probe in further I have had no problems after
    16 S3 with awe exhaust, usp downpipe, JB4
    2000 911 C2
    Sold 02 S4 with Apr stage 1 / millitek catback
    Sold-07 S4 with DTM kit, JHM tune, stasis exhaust, 19" VMR 710,
    Dec 03 2015
    Calgary, AB
    Thanks for the help everyone! I was wondering if anyone know the specific part number for the Blendmount radar mount since there are different mirror types on their website?
    Sep 29 2007
    Clarkston, MI
    2000 911 C2
    Dec 03 2015
    Calgary, AB
    Quote Originally Posted by tekkie View Post
    Thanks tekkie! I will for sure take a look at them
