Results 1 to 6 of 6
    Dec 03 2015
    Marseille France
    Quick question to APR or other tuner.
    To satisfy my curiosity i would like to know how the Fifth injector of the Flexfuel version of the B8.5 interact in the fueling?
    Is it just a super cold start devise or is it full time part of fueling?
    If it's full time part of the fueling why did Audi not go for bigger DI injector and skip that fifth injector?
    Tuner most know from the different map when that fifth injector is spraying?
    Jun 23 2013
    PacNW
    Quote Originally Posted by Mars2 View Post
    This. I believe Arin from APR has stated this on the forum probably in the one of the APR Tune threads.
    Veteran Member Three Rings ParadigmTony's Avatar
    Apr 02 2015
    Rochester NY
    For the record, I know very little about the flex fuel fuel system. However, in most cases this injector is for a few reasons. Cold start, high demand, and full E85. The difference in flow rate between fuels are why they didn't just go with a larger injector if Im not mistaken. I could be completely wrong, but have come across this on a few other occasions.
    //B8 A5 // 6MT DSB Pearl // Roc-Euro // APR // AWE // BBS // Bridgestone // StopTech // // K04/Stage 3v3/FMIC/Roc-Euro Intake/Test pipe-AWE touring/100oct life/19x10 CI-R/RE71R/ST60 BBK //
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by ParadigmTony View Post
    It's supposedly designed for e85 cold starts... Secretly it might help with keeping valves cleaner due to it being pre valve placement
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    I asked Arin this question a while back because I was hoping that 5th injector would help alleviate carbon buildup on the back of the intake valves. Unfortunately the answer was no, because it's only utilized on start-up.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    Quote Originally Posted by adamazing View Post
    I think the E85 alone helps. Heres my valves at 57K. The first 35K was ran using 91 gas, the last 22K was using 99% E85. Compared to the other pics posted in the carbon buildup thread, this is very minimal.
    Cylinder 1
    Cylinder 2
    Cylinder 3
    Cylinder 4
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
