Results 1 to 40 of 40
    Aug 25 2012
    Elmore alabama
    Help! No clutch after installing projectb5 clutch
    So I am trying to finish up my stage 3 build and I keep having problem after problem. I installed a new projectb5 clutch kit with a fidanza lightweight flywheel. I never disconnected the the slave cylinder line I just unbolted it and removed it. After I've put it all back together the clutch will not disengage. The pedal feels horrible almost like it has air in the system but I never opened the hydraulic system. Has anyone else had this issue?
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Were the pressure plate bolts torqued properly?
    Veteran Member Four Rings fixn2xlr8's Avatar
    Apr 11 2005
    Winston-Salem NC
    If its not too late the only regret I have stage 3 is the LWFW.
    Aug 25 2012
    Elmore alabama
    Pressure plates bolts torqued to 20nm per Elsa pro (Audi information).
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    If im not mistaken the project b5 clutch comes with a rs4 style pressure plate.
    That pressure plate has a self adjusting mechanism, you need to ensure that it is properly aligned before bolting it on to your flywheel or you wont have a clutch. If you didnt do this you will have to pull the trans out. I made this mistake too, thats how you learn on audis nevertheless.
    http://www.audiworld.com/tech/eng86.shtml
    Aug 25 2012
    Elmore alabama
    I understand what you are saying but from what I remember and the pictures on the website this pressure plate is not self adjusting. Is there any way that air could have gotten into the system? I am a technician at an Audi dealer but I don't have much experience with these cars as no one brings theirs in. The special throw out bearing supplied by project b5 was installed properly and the pressure plate was installed and torqued by applying even pressure all the way around. I just cannot figure out why the clutch won't release. Ident project b5 an email describing my problem, hopefully they will reply soon.
    Veteran Member Four Rings treysgreen's Avatar
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    Quote Originally Posted by rguil View Post
    Added to s4mods.com =)
    02 A4 5spd 1.8T Quattro ///
    01 S4 6MT /// - SOLD
    Instagram - s4mods ///
    http://s4mods.com ///
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I think those are usually a knockoff of a cm fx400 with a non-sac sachs pp.
    20nm is light and may be a prob down the road if they come loose. I do 30ftlb on steel fw and 25ftlb on alum. Loctite for all.
    This type off pp also needs a special tob.
    No clutch as in it just slips, or wont disengage?
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Aug 25 2012
    Elmore alabama
    It won't disengage, with the car on the rack you can get first gear but even with the clutch all the way to the floor the wheels are still spinning.
    Nov 16 2010
    WetSide, WA
    Did you use oem bolts on the fidanza? The p:b5 clutch hub is flat and the springs can contact the heads and hang it up.
    Other thing is too much angle while installing, or ramming the trans home with the belhousing bolts warping the disk and causing it to drag.
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    No one mentioned you could have misaligned the rod when installing the slave?
    Is it a stock slave? Those are a little weak at the c clip.
    If not a sac, then that's all I can think of.
    Nov 16 2010
    WetSide, WA
    Hed hava puddle under the car if something was wrong there.
    Aug 25 2012
    Elmore alabama
    I did not use oem flywheel bolts due to the fact I saw that it was hitting. The slave shouldn't be misaligned. It would push back out while installing.
    Sep 11 2009
    NE
    did you get tall TOB with that clutch?
    Aug 25 2012
    Elmore alabama
    Yes I used the tob that was supplied by project b5 which is much thicker than the oem one.
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Did you try bleeding the clutch? I know you didn't disconnect the line but air could have got past the slave rod deal with it fully extended. Try bleeding it and see if it gets better. Otherwise you will need to pull the trans to inspect further.
    Veteran Member Four Rings jballou's Avatar
    Mar 19 2005
    2007 Honda Fit
    Corona, SOCAL
    Did you install the Clutch disc in backwards? Seen that before. People think they can only go in one way, but believe me, somehow people can and do install them in backwards. But then again, you said that the peddle is sloppy. I would try to bleed the slave first (even if you never cracked it open,) if that doesn't work, looks like you are pulling the motor/trans again.
    2000 Audi S4 Stage 3,000 Million +
    Some crap just thrown together, puzzlingly making more power....
    YouTube Channel: http://www.youtube.com/user/jsballou
    www.tvme.info
    Aug 31 2011
    Lathrop
    Quote Originally Posted by zillarob View Post
    We do 23-25 ftlbs as well.
    20nm is 15ftlbs, which is nowhere near correct torque
    Edit* original converted to nano
    Oct 27 2011
    TOYS
    Philly Suburbs
    I do 30 ft-lbs and red loctite. My PP bolts loosened with the 22 nm Bentley spec.
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    That has to be a mistake in Bentley.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Aug 31 2011
    Lathrop
    Quote Originally Posted by slow ride View Post
    Bentley has an error on the 4.2l timing chain installation as well.
    Nov 03 2011
    All Over!
    If you opt to install the clutch slave cylinder whilst it's under pressure - ie you left the hard line connected, you have to be really careful when feeding the plunger into the recess.
    Whilst fighting against hydraulic pressure, it's all too easy for the plunger to miss the dimpled recess on the clutch release fork. If this happens, the plunger end will get jammed between the fork and the transmission case. You won't be able to disengage the clutch if this happens.
    As for aluminium LWFW, that's material for another thread.
    1986 Type 85 Audi 90 quattro
    Aug 25 2012
    Elmore alabama
    I have not bled the the slave yet even though that's the first thing I thought of when I felt the clutch pedal. With this clutch disc if I installed it backwards I should be shot, this disc will not go on but one way. I will try to bleed the clutch as its kind of pita to get to. And 20nm is around 15 ft lbs which does seem kind of wimpy but I went with the information that Audi has available.
    Nov 16 2010
    WetSide, WA
    I have used 22nm and loctite quite a few times with no prob.
    It finally caught up with me though, and 25/30ftlb ever since.
    The bolts that hold the driveshaft on are the same size so not quite sure why they would go so light on the pp.
    I think spark plugs are spec'd at 22nm
    Dec 17 2014
    San Diego CA
    Like a guy above said, ensure your slave is properly installed as well. you could remove the slave and install with the bleeder open to ensure proper install. Gravity bleed with the rear jacked up should be fine for a decent clutch feel
    Aug 04 2013
    Pennsylvania
    Yeah, I learned the hard way on the pressure plate bolts too. Did my clutch at 22nm, no loctite and not very long later I was doing it again lol.
    If the slave missed the fork you should have fluid everywhere... but it also seems exceptionally unlikely that air would somehow introduce itself into the system. But it never hurts to start simple. Pull the slave, be certain it's in properly, bleed it for good measure and see what happens. Otherwise, take it all back apart and hope you see something obvious lol.
    Practice makes perfect, it's like flat rate practice lol
    Nov 03 2011
    All Over!
    It is possible for the slave plunger to miss the fork, yet NOT lose any fluid, if the plunger is trapped between the fork and transmission case. In which case the piston won't over extend to the point of the seal popping out of the cylinder bore.
    It'll still cause a lousy pedal feel, and a clutch that will NOT disengage.
    May 16 2008
    South Texas
    We do 20 ft/lbs with blue locktite, never had a problem.
    Aug 25 2012
    Elmore alabama
    I bled the clutch with no help, noticed where there had been a puddle under the car and it was coming from the bell housing. Pain in the ass as it is I guess I'll be putting in another slave. Where does everyone get the medal slave cylinder from?
    Veteran Member Three Rings Mr. Merk's Avatar
    Sep 20 2007
    1988 911 Carrera 3.2
    NW Arkansas
    THIS^
    13 S4 3.0T | Her daily driver
    88 911 Carrera 3.2 | My fun car
    87 S-10 383ci drag truck | Her fun car
    05 Sierra 5.3L SLT Crew | My daily driver
    14 Jeep Wrangler Rubicon | Her other fun car
    Sep 11 2009
    NE
    Quote Originally Posted by Mr. Merk View Post
    THIS^
    Well, he already reported a puddle so obviously it is a typical rod miss with ensuing ejection taking place.
    Aug 25 2012
    Elmore alabama
    Hate to bring it up again but I have found why my clutch metal is lousy. After blowing out the second slave cylinder I removed it and inspected the hole. Turns out I can use a pick and move the clutch fork the approximate distance of the slave cylinder travel. With the clutch for against the pressure plate the slave cylinder is almost fully extended resulting in me either missing the fork or the slave to just not have enough travel to do it's job. Now the question is do I have an issue with the clutch or the flywheel. I have not yet removed the trans due to work load and I can not contact the person I bought the flywheel from or nick audlee at project b5. Could I have possibly gotten a flywheel from an a4? Or does this clutch not even work with a lightweight flywheel?
    Nov 16 2010
    WetSide, WA
    You prob just going to have to bite the bullet and pull it out. Good excuse to retorque the pp bolts.
    Take lots of pics for us.
    If the little black plastic wedge thing at the other end of the throw out lever is broke/missing, can allow the slave to overtravel and blow.
    Senior Member Two Rings rani_aridi's Avatar
    Nov 12 2013
    B5 S4 '00 BB
    Irvine, CA
    Forgive me if you said this before, but what throw out bearing are you using? It seems like that's the issue here.
    1998 Tornado red VW GTI VR6 - hit a tree. Broke the tree
    Aug 25 2012
    Elmore alabama
    The throw out bearing is the "special" one supplied by project b5 specifically for this clutch. Does any one know the difference in an a4 and s4 flywheel? I would imagine I would get crank sensor faults cuz I would imagine the the tone ring would be different but that's just me. If work allows I will try to pull the trans today.
    Nov 16 2010
    WetSide, WA
    Forget about the fw, that would be tough to do.
    Active Member Four Rings
    Sep 14 2009
    s.e. mass
    The clutch works with dual mass or lightweight flywheels alike
    -The only issue I have EVER seen someone report is the flywheel bolts hitting the disc's hub... fixed by chamfering or countersinking the flywheel bolts pending your flywheel of choice.
    Think about it, the aftermarket flywheels for the 2.7 are designed to use a factory clutch kit if you desired. Be it TTV, Fidanza, Clutchmasters, etc. The flywheel is not your issue unless whomever you bought it from sent you something we haven't seen or a damaged/inferior item, who truly knows
    The X-kit from PB5 comes with a spacer style TOB that Southbend MFG's. Its not cheap & they are specific to the clutch kit. A factory TOB wont suffice & will cause you a headache.
    You've already reported a big no-no with your install:
    1: (failed alignment of the slave = rod shot & puddle) QUOTE" I bled the clutch with no help, noticed where there had been a puddle under the car and it was coming from the bell housing. Pain in the ass as it is I guess I'll be putting in another slave. Where does everyone get the medal slave cylinder from?"/QUOTE
    I'd pull the transmission and inspect the fork/the pivot for it/etc. Shooting a slave rod missile /binding it and mashing the pedal / etc could all have fubarred something.
    I hope you figure out your issue, this clutch kit is well proven to work fine.
    IG: @PB5S4
    Sep 11 2009
    NE
    " Turns out I can use a pick and move the clutch fork the approximate distance of the slave cylinder travel."
    Sounds like a fork problem. You need to pull the tranny now and inspect all the parts to see if anything detached, especially the fork and its pivot.
    Aug 25 2012
    Elmore alabama
    Pulled the tranny and found no issue with the clutch fork, tob, or flywheel. I compared the flywheel to the dual mass and measures identical. I did find a problem with the pressure plate, the fingers on the pressure plate are way to far in. I emailed nick audlee again with the update. I'll post pictures after alittle while.
