Results 1 to 25 of 25
    Mar 07 2014
    United States
    Headlight/Interior Lights Cycling on and off
    I've got an 07 RS4 and starting a few days ago I got an error linked to the self adjusting headlights.
    It was wet out and I had that error once before and it never came back on after I cycled the power so I didn't think anything of it.
    That is until this started happening,
    https://youtu.be/dtKEbt0tI98
    It's all of the lights, headlights, interior, even the NAV colors will adjust. It's like the whole lighting system is cycling off and on. I noticed while this was happening the windshield wipers also pause momentarily. It also happens no matter if the lights are in auto or manually on.
    I tried pulling the codes and it was something about the auto levelers not having a baseline essentially. I pulled the diagnostics up and both of the sensors in the wheel well are not sending any info.
    I read that you can pull the fuse for that system (fuse 10) and it will kind of put a bandaid on the problem, so I tried that and got no more error code but the lights are still flashing.
    Any thoughts of places to start when I try and do some troubleshooting this weekend?
    Cheers,
    ~Mic
    Mar 07 2014
    United States
    Going to put the fuse back in and pull the exact code while on lunch,
    In the meantime I ordered new headlights because I what the heck?
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    Ordered new headlights? You serious?
    Mar 07 2014
    United States
    At this point I've read problems arising with the leveling system coming from 3-4 different areas,
    1. The sensors
    2. Ballasts
    3. Bulbs themselves
    4. Battery
    None of them have quite the symptoms I have now, but worst case scenario I pop in the new bulbs and it doesn't work. Now I've got backup bulbs.
    No one has given any sort of insight as to what might be happening in my case, so I've got to take the shotgun approach.
    Oct 27 2011
    Atlanta, GA
    Oh so you meant you bought new bulbs! Lol the actual headlights cost thousands, just making sure. I don't think bulbs are your issue since all of your electrical system is flickering isn't it? I was trying to figure out what was going on in your video. Maybe alternator is another area to check if it's all of the electrical system, or loose battery connection somewhere?
    Mar 07 2014
    United States
    HA! Yeah now I know why that might concern you, nah just the bulbs.
    I'm about to go out and trouble shoot now, but the only things are all part of the auto on/off lights EXCEPT the windshield wipers but those are automatic too. I don't know if they are all linked somehow. Some common relay or what have you. This car is still relatively new to me so it's trying to understand/diagnose a new platform
    Mar 07 2014
    United States
    Okay so VCDS codes
    Saturday,05,December,2015,13:42:36:21262
    VCDS Version: Release 15.7.2 (x64) Running on Windows 10 x64
    www.Ross-Tech.com
    Address 55: Headlight Range Labels: 4F0-910-357.lbl
    Control Module Part Number: 4F0 910 357 F HW: 4F0 907 357 F
    Component and/or Version: AFS 1 H01 0020
    Software Coding: 0000019
    Work Shop Code: WSC 06335 000 00000
    Additional Info: 8E0941329A AFS-Modul links H03 0010 8E0941329A AFS-Modul rechtsH03 0010
    VCID: 2959EEE280AA2C761C-807C
    2 Faults Found:
    01539 - Headlights Not Adjusted
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    Freeze Frame:
    Fault Status: 11100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Time Indication: 0
    00466 - Control Module for Steering Column Electronics (J527)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 40
    Time Indication: 0
    That being said, I found the lower front sensor. Where is the second one?
    Oct 27 2011
    Atlanta, GA
    I can dig it. Hopefully you sort it out. It's def not a common issue we are familiar with.
    Mar 07 2014
    United States
    I'm in group 2 of measuring blocks and it says front and rear sensors are undefined not sure what that's about
    Mar 07 2014
    United States
    If I go to basic settings it just continues to run group 1 no error no completion,
    I've let it run for a few minutes now
    Mar 07 2014
    United States
    Went to group 11 and i can make front/rear values change when i move the control arm
    Mar 07 2014
    United States
    OKay so I put everything back and was going to take it to advance to have the battery tested (my volt meter isn't very accurate) and after I started the car these things happened.
    Passenger window would crawl up a few inches and stop, rinse and repeat till it was all the way up. Then I tried the rear window, and it stopped and wouldn't move anymore.
    Radio shut off
    Lights shut off completely and wouldn't turn back on
    Car was still running at this point.
    Shut off the car and am pulling codes now, but everything went back to normal D:
    Mar 07 2014
    United States
    Okay got it to recreate the errors and electronics cutting out, here's what I mean by the windows cutting out somtimes.
    https://www.youtube.com/watch?v=WPKg0nIOTOA
    Here are the codes that rang up, new one is the last one and it has a headlight with an ! in the middle of it on the dash.
    Saturday,05,December,2015,14:33:01:21262
    www.Ross-Tech.com
    Address 55: Headlight Range Labels: 4F0-910-357.LBL
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 40
    Time Indication: 0
    00457 - Control Module for Network (J519)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Time Indication: 0
    Oct 27 2011
    Atlanta, GA
    I think you have some loose connections somewhere. Never seen this before. Maybe previous owner was fiddling with stuff? Aftermarket stereo maybe?
    Mar 07 2014
    United States
    Nope the previous owner was an older woman 45ish,
    If she did more than open the glove box I'd be shocked.
    Mar 07 2014
    United States
    I can now recreate the problem with everything shutting off and on pretty much at will,
    My rear drivers side window no longer wants to work at all...
    Systems that shut off (that I can tell)
    Lights (all)
    Radio
    Dash has turned to Celsius
    Windows
    Wipers
    Steering wheel controls
    Mar 07 2014
    United States
    Battery is officially fine....
    So no leads haha
    Senior Member Three Rings ImAudiHeree's Avatar
    Jun 30 2014
    Mercedes Metris
    Sacramento, CA
    Sounds like you got a short with the can bus system wires, or maybe your central convenience module is going toast it's a semi common problem on the audis.
    Mar 07 2014
    United States
    Is there any way to try and diagnose or solve the problem without taking it to the dealer?
    Feb 24 2010
    And have never been happier
    Was the alternator changed at any time? Connection to alternator may be loose..
    Mar 07 2014
    United States
    Not that I am aware of but I can check it,
    Wouldn't a loose alternator connection wreak more havoc (like ignition, etc) and also make it so my battery wasn't fully charged? It just read a 12.6 Saturday in the midst of all the problems.
    Mar 07 2014
    United States
    Bump anyone know the locations of these two modules?
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    J527 is on the steering column, it's what the indicator and wiper stalks are fixed to.
    According to vwaudiforum J519 is located "under the fascia below the relay plate and is mounted horizontally. You have to take the drivers side lower dash storage compartment out to access it."
    Mar 07 2014
    United States
    Great thanks!
    Feb 24 2010
    Quote Originally Posted by micmckee View Post
    It's just one of the few things I would check, if it has been touched (replaced,..etc). Once the engine is on, it will stay on, even if there is a loose alternator cable. But, it can create other lighting issues. If alternator hasn't been replaced or that wire hasn't been touched in a while, then maybe leave it.
