Results 1 to 6 of 6
    May 07 2014
    Anyone running APR k04 turbo with non APR test pipe and non APR software?
    Hi guys,
    I've just bought a K04 kit from a member on this site; it's just the core turbo, and I'll get the installation hardware from ECS.
    I do have a question though; I've previously purchased a Eurocode test pipe; will this be compatible? I would assume that if the APR K04 works with the standard CAT, then it should bolt up to this testpipe as well...
    Second question; has anyone tried running the APR K04 system with software from a company other than APR?
    Appreciate your feedback guys
    2010 A4 2.0t quattro 6mt
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by zokissima View Post
    Hi guys,
    If the stock cat bolts up to it fine, then the ECS HFC will too.
    I think a K04 is a K04, so you could run it with another companies tune, if you wanted. Though, I think your only options are Unitronic, Revo and APR right now. Revo would be tempting to me, if I was in your place.
    Sounds like the issues some are having with the APR K04 tune are being worked out.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Veteran Member Four Rings Dub_prime's Avatar
    Sep 10 2012
    2010 A4, 2008 Passat, 2002 GTI
    Bham AL
    Quote Originally Posted by blbroo View Post
    I may be mistaken, but I think the APR K04 is actually a hybrid using the K03 core machined to accept the K04 center section. So it bolts right up. The CTS kit is the "real" K04, "beautifully" adapted, that requires their downpipe.
    May 07 2014
    This is what I assumed, that if the K04 bolted up to the stock downpipe that it should work with the eurocode one.
    So, anyone have any feedback on the software they're running?
    Veteran Member Three Rings englishbay's Avatar
    Sep 30 2009
    Vancouver, Canada
    Quote Originally Posted by Dub_prime View Post
    Not sure where you got this information from. At one point I thought I would need to replace the turbo in my APR K04 and they said its the same turbo in the S3. There don't do any modifications to it.
    B8.5 S4 DSG | APR UC/TCU | APR Intercooler System | APR Intake | Bilstein PSS10s | Ethanol Sensor
    Sep 10 2012
    Bham AL
    Quote Originally Posted by englishbay View Post
    They are pretty vague on what they do to make it work, but now that I read it again they do say it's from that platform. I can't remember where I read about a hybrid before, but that's why I prefaced my statement with possibly being wrong. Guess they just clock it to fit the longitudinal platform.
