Results 1 to 13 of 13
    Senior Member Three Rings S6Express's Avatar
    Jan 14 2014
    Miami, FL
    Finalized the Stereo Setup after Disabling ANC in the B&O System - pics
    I finally finished my stereo system.
    I set out to install a sub and amp to add a little thump to the factory B&O system which sounds great out of the box, but lacks the tight bass I'm used to.
    After installing my initial system I had a horrible noise that was generating through the sub from the Automatic Noise Cancelation (ANC). It took me a while, but I was able to disable the ANC by pulling the four pins on the amp that control the ANC.
    After getting the ANC out of the way I was happy with the results of the bass, but the trunk is too well sealed to let the bass through. I had the stock B&O sub that came mounted under the parcel shelf (a system that was changed to the sub mounted with the spare tire in the 2014 model). I thought that keeping the 8" B&O sub would a nice little mid bass, but that wasn't the case. All it was doing was keeping the real bass out of the cabin and it would distort at high volume. So I removed the B&O sub and now there's nothing in the way of letting the sound come through. Sounds much better without it than with it. Then I Dynamatted the parcel shelf to avoid creeks and rattles.
    I had a Rockford Fosgate Punch Stage 3 12" sub and amp, but the 12" bass was a bit sloppy and I wanted a bit tighter bass. I considered an open air (infinite baffle) 10" sub to mount onto the parcel shelf, but I was warned against it not producing great bass. I also wanted something that I could easily move around in case I need to put something large in the trunk. So I ordered a JL Audio Pro Wedge CS110-W6V3 10" Sub in it's sealed factory box. It's a very compact unit it it sounds great. The 10" W6 sub can handle up to 600W. I mated it to an Arc Audio XDi 1100.1 Amp and it sounds fantastic, it delivers 500W for the ohm configuration of the JL sub. Hard hitting bass when you want it and nice complement when you don't. To control the amount of bass I ran a two pairs of RCA cables from the amp to the front next to the steering wheel so I can have a PAC LC-1 level controller that controls the gain from 0-100%. To keep it clean I took apart the LC-1 and my hard wired Escort SmartCord and I enclosed them both in the same project box. I'm very happy with the results, I had a lot of trial and error, so I thought I would write this post in case anyone might find it useful.
    2013 S6
    Ibis White / Black Int / Innovation / Bang & Olufsen / LED Headlights / Carbon Inlays / Black Headliner / Sunshades / Cold Weather
    Mods:
    HRE P47SC 21" x 9.5" Wheels / RS7 Rear Diffuser & Oval Exhaust Tips / Red Bembos / Bigger Rear Spoiler / Dead Pedal S6 Badge / Black Wrapped Grille Slats / Black Wrapped Grille Edge / Black Window Trim / K&N Drop In / Escort Max360 Hardwired w/ Remote SmartCord / VAG COM Mods / 35% Tint
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    Neat! Cost? Do you feel like the "mid" level bass is hit better? The stock Bose system (in Prestige models, not sure if it's the same as regular models) has great highs, decent mids, and OK lows but it misses some of the lower-mid bass frequencies entirely.
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Jan 14 2014
    Miami, FL
    Quote Originally Posted by hubris View Post
    Sub and amp were $900.
    The B&O system has great mid bass, the doors can thump. The new sub and amp excel at the lows, not bid bass, but the mid was never a problem with B&O.
    2013 S6
    Mods:
    Veteran Member Three Rings B5SilverS4's Avatar
    Oct 15 2006
    02 Porsche 911 Turbo, 94 Mercedes E500, 14 Porsche Cayenne GTS, 91 BMW 318I, 05 Mercedes CLK55 AMG
    Charlotte, NC
    Nice work!
    2016 Audi S8 Plus
    2014 Porsche Cayenne GTS
    2005 Mercedes CLK55 AMG Black on Black, Kleemann, Renntech, BBS, Bistein, etc.
    2002 Porsche 911 Turbo Lapis Blue Metallic, BBS LMs, H&R Coilovers
    1994 Mercedes W124 E500
    1991 BMW 318IC (E30)
    Sold - 2008 Mercedes CLK63 AMG Black Series
    Sold - 2013 Audi S6 APR, HREs
    Sold - 2001 Audi S4 Nogaro Blue w/Black interior, APR, Stasis, BBS, etc.
    Sold - 2003 Audi RS6 Daytona Gray Pearl w/Platinum interior, 10SecS4 Tune, MTM TCU
    Veteran Member Three Rings BlueSVT's Avatar
    Oct 06 2013
    I too am very happy with the overall system after adding a sub to the B&O... once I figured all the BS out!
    People are amazed at the overall quality.
    Arguing with an engineer is a lot like wrestling with a pig... After a couple hours you realize the pig likes it.
    Veteran Member Three Rings jstrebel's Avatar
    Oct 02 2006
    Tucson, AZ
    May I thread jack and ask where you got the red cargo liner? Brand?
    2005 A4 1.8t Ultrasport: SOLD.
    2016 S7: Build Thread - SOLD
    2023 R8 AWD Performance: Build Thread
    2024 RS6: Reel
    Jan 14 2014
    Miami, FL
    Lloyd Mats, Rubbertite series. They come in a bunch of colors. I thought red would pop and it does. I get tons of compliments.
    http://lloydmats.com/mat-materials/r...s-trucks-suvs/
    Quote Originally Posted by jstrebel View Post
    2013 S6
    Mods:
    Senior Member Two Rings Pampedout6's Avatar
    Jun 26 2015
    Southern NJ
    Great install!! I had my local audio shop install my Rockford P3 with a 1500w amp with a custom box. Poor dude was freaking out because of the ANC, I told him let me have a crack at it, disabled ANC with VAG and was good to go. Like you, bass hits hard when I want it and mellow when I dont.
    Sent from my SM-G925F using Tapatalk
    2016 with Prestige package, Sports Package, Night Vision, Cold Weather, Driver Assistance, APR Stage 1 ECU/TCU, 21" Vossen VFS1's with Michelin PSS in 255 35 21, Weather Tech Mats, ROC Euro Air Intake, 3M Tint at 20%, Exhaust resonator delete with H-pipe, VAG Mods
    Aug 02 2016
    Quote Originally Posted by Pampedout6 View Post
    Pampedout6,
    I have a 2016 Audi TTS with B&O. My local audio shops won't touch the car because of the ANC. Dealership tells me if I unhook the ANC mics the system will go into safe mode and shut down. Is it really that simple to fix with VAG? Thanks
    Veteran Member Three Rings Marc R's Avatar
    Jan 29 2017
    Amsterdam
    I'm very interested in how to disable the ANC
    Aug 02 2016
    Quote Originally Posted by Marc R View Post
    Marc I if have success with it I will let you know.
    Im trying to do the same. How fo I disable my ANC ? And what items do I need to get audio signal to amp ?
    May 16 2017
    MD
    Little bit of an old thread, but I'm curious if anyone figured out how to disable ANC through vcds.
