Results 1 to 22 of 22
    Nov 30 2015
    New York
    Question OIL LEAK and Weird sound? ideas?
    trying to figure out why this is happening....idea?http://www.youtube.com/watch?v=1Yi7F0vHmHA
    Senior Member Three Rings mfdk's Avatar
    Jul 25 2012
    A4 B5 V6 2.8l
    Fort Mill, SC
    Cant tell based on your video where the noise is coming from, but i can tell you that last time i had that noise it was my Timing chain tensioner in the back of cylinder head.
    How many miles on the car and any maintenance done recently!
    Edit;
    As fas as the oil leak, its pretty obvious on the passenger side that's your valve cover gaskets need changing, as for the driver side the only thing can leak around that area is the gasket for the oil filter housing.
    Sent from Outer Space
    Nov 30 2015
    New York
    Quote Originally Posted by mfdk View Post
    Edit;
    Thank you for the info!
    I had the car not long ago at the dealership. They did said I needed a timing belt tensioner but the picture that they had on the booklet made no sense bc I was gonna buy it in my own and now that u said timing chain belt, I see that it was the tensioner from the chain itself and not the belt. They were gonna charge me 450 for it. U think that's worth it?
    Car is about to hit 95k
    Jul 25 2012
    A4 B5 V6 2.8l
    Fort Mill, SC
    If they do replace the timing chain tensioner and the chain itself for $450, thats actually a really good deal.
    Genuine Tensioner is about $145 to $165
    Timing chain itself another $140
    I would be surprised if they replace it for $450, is that including the parts or just labour..? If you have to do it yourself you will be spending close or more then $450, since you need specialty tools.
    Nov 30 2015
    New York
    yeah, parts and labor. and no, just the tensioner itsel. but its confusing bc the picture that they have doesnt look like a timing belt tensioner nor the belt chain... will post a pic of it soon. trying to figure out how to do it
    edit: 450 plus taxes
    Nov 30 2015
    New York
    This is the picture they showed me.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    Senior Member Three Rings johnruan's Avatar
    Oct 01 2014
    Audi Q5
    chicago,il
    It don't look like tensioner
    Nov 30 2015
    New York
    Quote Originally Posted by johnruan View Post
    thats what im saying. it makes no sense. they either put the wrong pic under the name, or it was something else
    Jul 25 2012
    A4 B5 V6 2.8l
    Fort Mill, SC
    Quote Originally Posted by bfunk1414 View Post
    I took my b7 apart and never came across a part like that...
    May 20 2014
    e92
    Reading the partial word in the picture, that is definitely not a timing belt tensioner for B7. Although, I have no idea how a chain tensioner looks like.
    Oct 01 2014
    Audi Q5
    chicago,il
    This is chain tensioner
    Nov 30 2015
    New York
    I know. That's the funny part. It doesn't even look like neither of them. I guess I should create a thread about ppl trying to identify this part lol
    Active Member One Ring Ilya K.'s Avatar
    Nov 21 2015
    1979 MG Midget Track/Street 2002 Yamaha R6
    Ray Brook NY
    If I'm not mistaken that's a part of the timing belt tensioner for a 3.0. I don't recall seeing anything like that on a 2.0, maybe a 1.8 but its been a pretty long time since I've done a timing job on one of those
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B9Q5
    Honolulu, HI
    The oil filter housing gasket looks like its leaking and the valve cover gasket looks like it needs to be replaced as well.
    https://www.europaparts.com/oil-filt...06f115441.html
    https://www.europaparts.com/valve-co...6f103483d.html
    Current:
    2024|A5 SB PP+ S-line, 2019|Q5
    Previous:
    2017|S3, 2016|A4 2.0T Quattro, 2006|A4 Avant 2.0T Quattro S-line, 2005|A4 3.0 Quattro UltraSport
    Nov 30 2015
    New York
    Quote Originally Posted by DoThisMyWay View Post
    Thanks a lot for the links. Didn't expect them to be so cheap.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Do the valve cover yourself is easy. Do your spark plugs and coil packs while you're at it
    Nov 30 2015
    New York
    Quote Originally Posted by Sanjman View Post
    About to rodee the covers. Already got the spark plugs. No time to order the coils but I'll replace it later. As well as the timing chain tensioner.
    Nov 16 2006
    Skokie, IL
    Also take a wet rag and brush and clean all the oil residue off. This will help you figure out if it's leaking again. Also my theory is that valve cover gasket go because there is an underlying problem related to your PCV or related items
    Nov 30 2015
    New York
    Thanks for the input. I did some research and that tends to be why the leaks happen. Would u recommend to replace the pcv hose too or just the valve itself?
    Nov 16 2006
    Skokie, IL
    Valve only. But only real way of telling is by doing a leak test the hose is expensive iirc
    Nov 30 2015
    New York
    Will do. Thanks! !!
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Your engine noise sounds pretty much normal for a 2.0 FYI...As for the oil leak, replace the following gaskets;
    1) valve cover gasket (passenger side oil leak)
    2) oil cooler gasket (driver side leak)
    3) oil filter housing gasket (driver side leak)
    Probably no more than $50 in OEM parts....But several hours of labour. For #2 and #3, I have the same issue...Search this section and you'll find previous threads about them.
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
