Results 1 to 10 of 10
Thread: Seats
    Senior Member Two Rings nemick's Avatar
    Aug 22 2012
    Indianapolis, IN
    Seats
    Will seats out of any other Audi fit in the B5 A4? Just trying to do something about the typical torn driver's seat without going broke.
    Thanks
    Neil M.
    2004 allroad 2.7T TIP
    2001 A4 1.8TQ, TIP
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Any other 1.8 seat will fit. The next step is s4 seats, which need modification.
    If all you want is a nice driver's seat, find a passenger seat somewhere and you can swap the cover over.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Four Rings crazexr7's Avatar
    Sep 10 2011
    1998.5 A4 2.8 Quattro, 2001 Porsche Carrera 4, 1968 Cougar XR7
    Bristol, CT
    Grab an unripped passenger seat bottom from a partout, junkyard, or ebay, and swap it onto you driver seat. Others have done it before and it works great
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Sport Cloth seats are an OEM option that have the same bolstering as S4 seats, but are manual and decently rare/desirable. Because they're manual they sit lower (at lowest setting) than S4 seats, which is great for taller people like me (6' 3").
    But before I got my Sport Cloth seats I did a passenger seat cushion swap onto the torn driver's seat. Worked out great.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Feb 10 2009
    '01 A4, '87 Chevy 1 Ton
    Knoxville, TN
    Quote Originally Posted by redline380 View Post
    so will B6 seats swap over? Because I think if B6 seats swap then I imagine B7 seats would too. I swear I read somewhere that B6 and B7 seats are interchangeable
    1988 Shelby Dodge CSX-T, 2.5L 4cyl, T04E 40 trim w/ .63 A/R, Stg2 Ported 8v Head (Sold) it was a torque monster!!! :(
    2001 A4 1.8T turbo back 2.5in exhaust, SB clutch w/ 17lbs SMFW, Forge splitter, Revo stage 1 flash, 4:1 Center diff, ST Coilovers, 034 RSB, Forge FMIC.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by juxsa View Post
    b6/b7 are interchangeable, just not with b5's
    2000 S4- Working?
    Jun 30 2008
    Erie, Pennsylvania
    You can fabricate them to fit. The fronts anyway. It's a bit of work, though. You have to build things.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    B6/B7 seats will take some major modification and fabrication to get to work.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Jun 30 2008
    Erie, Pennsylvania
    They look pretty great, and the rears will fit, too:
    http://www.audi-sport.net/xf/threads...to-a-b5.26517/
    Doesn't look like they'd be too hard to put in with the right hardware:
    http://www.audizine.com/forum/showth...seats-in-B5-S4
    Bracket dimensions for retro fitting the front b6/7 S4 Recaros to the B5:
    They don't look terribly complex:
    Jan 16 2006
    LA CA
    I thought about putting b7 seats into my car. I wonder if I can get any brackets from anyone? I know there was a group buy a little while back. I already welded in B5 S4 seats. To anyone contemplating this swap. WELD the base, don't use rivnuts.
    Do you know if the rears are the same for the avants?
