Results 1 to 40 of 61
    Sep 12 2014
    Long Island
    Gauge Pod options, or Lack thereof?
    So I was looking to put a couple aftermarket gauges in my car and the biggest problem that I seem to be running into is the selection.
    Now I understand the whole thing about the A-Pillar airbag but I figured there would be a pillar pod(preferably triple) option available but there really isn't. In terms of steering column the b5 seems to be one of the few platforms that doesn't have a dual option for the top side of the steering column and I was kind of curious as to why that was if anyone had an answer?
    Ideally I would run a Triple Pillar setup and then have 3 other gauges somewhere else. For the 3 not on the Pillar I was probably just going to do the 3 vent sections in the center of the dash unless somebody has a different idea?
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    I'm in the process of making some steering column mounted pods. I made 1 for myself to hold my wideband and boost gauge.
    It Will nearly look factory when finished, and you can still see all important bits on the dash too.
    Sep 12 2014
    Long Island
    Any reason there are no aftermarket options for the dual steering column setup?
    May 16 2008
    WA
    The A-Pillar airbag fear tends to get blown out of proportion a bit, as I think people have a misconception of how it works:
    May 16 2008
    WA
    What are you trying to keep tabs on exactly? Information is great, but running 6 extra gauges will likely just get distracting.
    Boost and AFR are likely the two with the highest priority.
    Remember, " Less is more". You don't want to get to this point lol:
    Nov 16 2014
    ovid ny
    Not to thread jack. This is just my idea. But Im looking to runing a single din cd player in my car. That would give plenty of room for 2 maybe 3, 2 5/16 gauges above it. I have seen single din plates that would make a good start
    Established Member Two Rings Gotwake424's Avatar
    Dec 14 2014
    DavidhogAJ
    Philippines
    i swear i saw duel guage pods for the steering column very recently while researching W/M kits
    Sep 12 2014
    Long Island
    The Triple A Pillar would be for Boost, AFR, and something else the 3 in the vents would most likely be for airride monitoring as in PSI for all 4 wheels and the tank
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    Quote Originally Posted by Gotwake424 View Post
    There is...I know this because I have one.
    Look up dual gauge pod for the b5 passat.
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    There is a company that does custom rear view mirror gauges. Link to their site is below and they should be able to do custom gauge installs.
    http://www.radar-mirror.com/index.html
    Established Member Two Rings kmikuta's Avatar
    Jul 11 2015
    Laser B5 S4 Project, B8.5 S4, '63 LSX Chevy 2
    Chicago, Il
    Center vent DIY, look it up. Cleanest looking gauge setups IMO and the vents remain functional. Keeps the car a bit more sleeper as well, because the drivers next to you won't see them as easily as a pillar pod, especially at night.
    Sep 12 2014
    Long Island
    I was most likely going to do both lol
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    A dremel, some patience, time, and a center vent will give you really clean OEM results. Anything you dont look at regularly, toss in the glovebox.
    Sep 12 2014
    Long Island
    I think I'm going to do the DIY vent pod but does anyone have personal experience with this mod, like how the pods stay in with a quick acceleration or any sort of movement?
    May 16 2008
    WA
    Quote Originally Posted by tmaclax013 View Post
    since you are using the factory vents as a base, they click in like the factory vents (snug and strong). So they wont have any issue falling out under acceleration, and the built in metal side "spring" keeps the vent from dipping downward. As long as you don't make your center hole too large, the gauge should stay snug in the vent too.
    Sep 12 2014
    Long Island
    So theres no anchor mechanism just friction around the pod?
    Veteran Member Three Rings goalieman24's Avatar
    Mar 29 2011
    It just sits in there. You could probably fab something up if you wanted extra piece of mind. Even like a zip tie around the gauge on the inside of the vent would create a lip that would hold it.
    But just keep the hole small to start and then very gradually make it big enough to hold the gauge.
    May 16 2008
    if you really take your time, you can cut the hole so it fits snug in there. On mine, you can pull it out, but you actually have to pull. I've never had it come out under any circumstance without purposeful help.
    May 16 2008
    WA
    friction is all you need. If the gauge flies out under acceleration, either 1] you cut the hole too big, in which case i guess you could wrap some electric tape around the gauge body to thicken it up, or 2] your s4 has rocket boosters as a means of power.
    measure twice, cut once, and you will be fine.
    If you were really worried about it you could use the gold "u-bar" locking plate that comes with most gauges (as seen below) on the backside (or just make one), for extra confidence...but 100% not necessary:
    Jun 08 2014
    Vancouver, Washington
    Quote Originally Posted by getslideways View Post
    I've got a boost gauge currently, but what is so important about an AFR gauge? I know it reads the air fuel ratio but is that actually important to know with anything below stage 3?
    May 16 2008
    WA
    If you are stock or running an off the shelf tune, the chances of you needing it are likely low. Its just an extra piece of mind as if your engine started running lean while WOT (due to low fuel pressure, post maf intake leak, etc) the motor could quickly commit suicide.
    I know what to expect when going WOT from my boost gauge and AFR gauge, so if in a quick glance i were to see them anywhere outside what I would expect to see I know to back off and save the motor. Thankfully thats never happened, but it did help me track down my faulty egt sensors when the car was sluggish and the AFR was showing really rich fuel levels.
    So is it needed? No, its just another diagnostic tool in most cases.
    Jun 08 2014
    Ah okay I understand. Thanks!
    Veteran Member Three Rings Kenrevo's Avatar
    Aug 05 2013
    MA
    I got a 2 pod for the a pillar, that was for the b5 a4/s4 but the fit is terrible. My next project is to take a mold of the pod and the pillar and make one continues piece. I'll try and take pictures tomorrow.
    '01.5 S4 F21 on meth -- DD
    '05 Touareg V8, loaded
    '00 A4 1.8t Avant SOLD
    '99.5 A4 2.8l 30v QMS SOLD
    Senior Member Two Rings Schläfer's Avatar
    Feb 02 2013
    04 Sierra and 87 V8 S10
    So*Cal IE/LA
    Doesn't Podi make a dual pod for the column? I swear I saw it on their site when I bought mine.
    *Schläfer*
    May 16 2008
    WA
    Quote Originally Posted by Kenrevo View Post
    I picked up one of those A pillar ones that was molded into an entire OEM pillar and wrapped with the OEM fabric. Not sure who sells them now as I got it used but it fits great and almost looks like it is supposed to be there haha
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    ^I've got the same one, I forgot the company name, sure they haven't made them new in over 10 years though
    And see if you can spot the "creature" in the pic (which is the main reason I took this photo) Hint...they are supposed to mean good luck
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    Quote Originally Posted by xalents23 View Post
    I've seen this before, pretty neat. I intend on diy-ing one of these in the near future. You can hook up up to 14 sensors afr/boost/oil pressure etc. Get rid of that stupid column pod that blocks a shit ton of my cluster
    2002 Pearl/onyx S4 Avant
    Aug 06 2008
    Canadia
    Podi makes a b5 column mount gauge solution, replaces the top oem plastic piece for a factory look.
    the B5 S4 is like the mafia... there is only one way out!
    May 16 2008
    WA
    Quote Originally Posted by TheDarkness View Post
    Thats the one! Maybe SSP??? My brain is old, so maybe not
    As for the pic, I am guessing:
    A) A Praying Mantis on the windshield
    or
    B) A Pterodactyl in the power lines
    Veteran Member Four Rings bobkatkat's Avatar
    Jun 07 2012
    North of the 49th parallel
    I have another one of these in the works this time with USB and 12v power for things like radar and phone, along with the EGTs. Still a great location for info displays.
    Dec 14 2014
    DavidhogAJ
    Philippines
    ^ Clean!
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by bobkatkat View Post
    That definitely looks pretty legit and clean.
    I've got a similar project in the works for the center visor, which uses a 16x2 LCD (red characters on black background) and Arduino. Here are my plans for it:
    1) Boost/vacuum (auto-switch, ~5 Hz refresh), and temperature-corrected barometer
    2) Oil pressure, including alarm
    3) Fuel pressure, possibly with alarm (correlated to boost/vacuum readings)
    4) EGT (if I care enough, not a big issue on 1.8T)
    5) Turbo timer
    6) Maybe have access to OBDII through a dongle
    Haven't touched the code or hardware in 3.5 months though . Gotta love when life gets in the way.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    May 16 2008
    WA
    Quote Originally Posted by MetalMan View Post
    5) Turbo timer
    Would love to follow a build thread for your gauge project
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    One of these days when I hop back on that project I can throw some words and pics together. Presently the project only exists as bits of code and a breadboard, but so far I have menu cycling, boost/vac display, compensated barometric pressure display, and framework for turbo timer implementation.
    I will admit that I received inspiration from al3k87's "Boost Box" project in the B7 section:
    http://www.audizine.com/forum/showth...1#post10487488
    He was nice enough to post his code publicly, so some of my boost/barometer code stems from his.
    Jul 04 2012
    Woodbridge, VA
    Cleanest gauge option. And you can add other sensors
    Apr 04 2007
    2001.5 S4 Stage 3+, 2001.5 A4, 2000 Porsche Boxster S, 1969 MG CGT, 1974 MG Midget
    Orlando, Florida
    Quote Originally Posted by aysix View Post
    This. I have the same one. The texture doesn't match and the shape is a little off. I just heated it up and formed it around the colum surround. One of these days I may get it done in carbon fiber just to make it look better. I think I got mine from Summit for somewhere around $25.00
    Jul 13 2008
    it's SPP I think...and yes, A is correct. Yet I didn't see B until you mentioned it, sweet.
    here: http://www.audiworld.com/forums/s4-r...night-1409962/
    or
    Nov 02 2012
    Indianapolis, in
    Quote Originally Posted by vavJETTAw36 View Post
    That's the one I linked I think. Up to like 14 sensors. Glad to see it in a b5, was curious as to the fitment..
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by 88ninety9 View Post
    Easy install. Only complaint is brightness level doesn't match. But I don't mind. Oh and if you're are wearing polarized lenses you cannot see it.
    Established Member Two Rings Ripcord's Avatar
    Jun 06 2013
    http://audisrs.com/archive/mod-b5-rs...__t_23411.html
    Boost gauge in place of the Voltmeter.
