Hello Iam an owner of a 2005.5 Audi S4. I have been experiencing a major problem with random misfires. I have changed the coils along with the plugs and the misfire continues to show up. The check engine light also begins to flash once I hit high rpm's. The codes the car is reading are
1.) PO300 , multiple misfires detected
2.) PO305- cylinder 5 misfire,
3.) PO308- cylinder 8 misfire,
4.) PO306-cylinder 6 misfire
5.) PO304-cylinder 4 misfire
1.)I have had the audi dealership tell me I need to have my timing chain fixed and this is what is causing the misfire.
2.)However, I also know a guy who works for audi and tells me that I need to replace the cats because they are torn apart and this is what is causing the misfire.
3.) Another mechanic says it cant be the cat because the car has low pressure on the spark plugs
If anyone has experienced this similar problem and knows the solution. Any help would be apprecited by the audi community.
