Results 1 to 18 of 18
Thread: Stripped Studs
    Established Member Two Rings SlowestB7ever's Avatar
    Jul 04 2015
    2001 B5 S4
    Buffalo NY
    Exclamation Stripped Studs
    Ahem...whilst upon reinstalling my turbo, things just weren't lining up correctly, the damn manifold just wouldn't wann go into place and I thought, "hey why don't I just force it on!" (Eureka right?) to make a long story short, I've got two stripped studs and two stripped nuts, those being the ones that hold the manifold in place. I messed up entirley. Guess I got too excited to see my car run after 4 months of dormancy. What are my options for DIY?
    6 trips to the parts store, 4 days of missed work and a couple higher pounds in blood pressure, it's finally finished
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Replace stud and nut, install manifold.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Jul 04 2015
    2001 B5 S4
    Buffalo NY
    Entirely forgot to mention and feel like a bigger dummy but, two holes are stripped for the studs
    Feb 09 2013
    WNY
    Oh... The holes in the cylinder head itself are stripped? Only thing I can think of would be to use a helicoil.
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    Clean out the hole and retap it and buy specialty bolts..?
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Mar 24 2013
    Oakdale, CT
    Helicoil the hole and put a new stud in. Problem solved.
    -Adam
    Jun 27 2011
    Came for naked dudes. Was disappointed.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings Rabbit's Avatar
    Aug 17 2009
    Unicorn shit
    PNW
    Jun 17 2013
    jersey city nj
    ^^^^^this orby drill and tap oversize. Use oversize stud and nutz. You can get them from https://www.fastenal.com/ Had experiences with heli coil exhaust studs and bolts. They tend to expand and contract to much for the application
    Mar 24 2013
    Oakdale, CT
    If you go with an oversized stud, you may need to drill out the manifold.
    -Adam
    Jul 04 2015
    2001 B5 S4
    Buffalo NY
    Should I decide to go oversize, would m10 be ideal?
    Jun 17 2013
    jersey city nj
    ... Forgot to mention that
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by SlowestB7ever View Post
    Id just ed, the M10 looked like the size of the exhaust studs from the catalytic converter. That would be to thick. Mite have to the heli-coil trick like aluthman suggested.
    Jul 04 2015
    2001 B5 S4
    Buffalo NY
    Should probably ask this too, are any of the nuts/studs on the exhaust Manifold used for piloting or should everything just fit like a glove back into place immediately
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    lololololololololol Waite for president 2016
    Mar 24 2013
    Oakdale, CT
    Nope, the manifold is held in place mainly by the lower shelf setup. The studs along the top simply hold it tight against the head.
    -Adam
    Jun 27 2011
    I knew at least to would appreciate the comment.
    -CP
    2017 Q7 3.0t
    Dec 05 2007
    Relevance to thread, is the female threads on the cylinder head stripped for sure?
    I ask because this happened to me and I heli coiled for no reason. After the first one, figured just try and see if a "brand new" stud would go in. Lo and behold, threads in and locked no problem. So, didn't even have to heli coil the other ones in. Even though the "stud" male threads are stripped, doesn't necessarily mean the cylinder head female threads are stripped too. But by looking at the stud threads, you would expect it to be. This happened to both my cylinder head valve cover studs and exhaust manifold studs (few of each). So in a nutshell, first try and place a "brand new" stud in first. You may be surprised. You can also try chasing the threads first, too.
    I particularly don't like heli coiling these studs because you have to be pretty much precise with the angle. The further end of the stud when finished will reveal how much off you really were...and it can cause another situation. This also happened to me and had to drill all my manifold holes slightly larger to compensate. Sucked ass!
