Results 1 to 12 of 12
    Senior Member Two Rings Kay87's Avatar
    Oct 17 2012
    2012 Audi S4, 2006 Audi A4
    B.C
    RFB Reverse Led error from USP motorsports
    Installed these http://www.uspmotorsports.com/Audi--...ED-Lights.html today. They claim these led won't give out any error, but I get error from both sides. Is disabling error through Vagcom the only way?
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Odd, worked on both my B8 and B8.5 just fine.
    Edit* would throw errors if I out it in reverse quickly after starting. Would wait about 10 seconds and it resolved this issue.
    Oct 17 2012
    B.C
    b8 and b8.5. Do they use the same reverse led bulb?
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    Yeah - mine pop with errors about 2x/3x a week - not every time into reverse though..... And they go out next time around.
    That reminds me to pickup some dialectic grease to try and see if that helps.
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Jul 25 2010
    WI/IL
    Quote Originally Posted by Kay87 View Post
    Yep, I've used them in both my cars. One thing I will say, i did notice if I threw it in reverse quickly after starting it would throw an error. I would usually wait about the duration of the automatic headlight leveling before putting it in reverse and never got errors again.
    Oct 17 2012
    B.C
    Quote Originally Posted by jl87 View Post
    Oooo... I will try that later and report back
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    I have some similar code free ones and if your battery is low, you will get the bulb error on the first reverse of the day. I landed up coding mine out.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Senior Member Two Rings Nightkiller6's Avatar
    May 30 2015
    San Diego, California
    I have these and I have never gotten an error.
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    I got an error bc I forgot to turn the car off while replacing them on my 2015 b8.5 the reverse are in the outside lights and not in the trunk hatch so I wanted to make sure which was which since some cars had four. Restarting the car cleared the bulb out code though.
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Registered User Four Rings Phil@USP's Avatar
    Sep 18 2012
    Coral Springs, FL
    Thanks for the feedback guys. I will take these notes to our team to see what they say.
    Oct 17 2012
    B.C
    You are right same thing for me too. If I go reverse too quick after engine start I get bulb error. And like you said wait 10 secs to avoid error.
    Jul 25 2010
    WI/IL
    OK cool, glad it resolved it for you.
