Results 1 to 18 of 18
    Jun 13 2011
    Beverly MA
    Rear alignment totalled boned
    98 A4 Quattro and multiple shops cant seem to get the rear aligned. Specifically the drivers rear side. Current specs on the rear -1.9 degree camber and -2.33 toe left side. Right side -.08 camber and .67 toe
    Thrust angle is showing as -1.5 degree. Is my rear end totally shit at this point?
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    Quote Originally Posted by Sidewayzracer View Post
    did you hit a curb or a really big pothole at some point? I had a similar issue on my prelude and you could see the bend on the control arm. it was a small bend, but it made my car jerk to the right on a bump or puddle.
    Jun 13 2011
    Beverly MA
    Nope though i have a feeling the PO had as the first set of tires on it wore out quickly, the car hasnt been driven much since ive bought it 2 years ago.
    The shop said they didnt see a bend in any of the arms and might think the mounting points for the arm
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Probably a bent upright/spindle.
    Sent from my Jailbroken iPhone 6s 9.0.2 using Tapatalk
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Shifted subframe is my guess
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Feb 27 2011
    Winnipeg
    I'm with redline on the shifted subframe, could possibly be bent, wonder if the eccentrics are seized and shop just says they can't get the specs cause they're too lazy to try
    Oct 09 2012
    Quote Originally Posted by redline380 View Post
    But the other side is almost in spec. Wouldn't a shifted frame make both sides wack?
    Op is there more adjustability on the right side tow essetric bolt?
    Somthing has to be wrong though with the left side so out of spec.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Jun 13 2011
    Beverly MA
    Right side eccentric was snapped and welded and has been replaced
    Jun 30 2008
    Erie, Pennsylvania
    I don't think the other side is almost in spec. There is not enough camber and way too much toe in.
    Due to the lower control arm AND tie rods both mounting to the subframe, all of the symptoms point to the subframe being shifted significantly in one direction.There certainly could be something bent, so definitely inspect closely - but I would try shifting the subframe to see how much can be corrected.
    Worse come to worst (chassis is bent), you can do some quick and dirty fixes to get things within reason. Things like hogging out the subframe mounting holes to get more movement, spacers between the shock mount brackets and body, adjustable-length rear tie rods for increased adjustment range.
    Oct 09 2012
    I have a set of 034 forsale.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Jun 13 2011
    Beverly MA
    Looking into getting some quotes for the straightening, was very close to parting out the car if i cant get the rear unfucked up
    Feb 27 2011
    Winnipeg
    its stupid easy to do yourself, there are 4 bolts holding the rear subframe in, loosen all 4, slide subframe in direction you want and tighten 4 bolts back up (replace the bolts if you're a keener)
    Jun 30 2008
    Erie, Pennsylvania
    ^I just learned a new Canadian slang term.
    keener - Canadian [informal]: a person who is who is extremely eager, zealous, or enthusiastic.
    "keeners who spent most of high school buried in homework"
    Sounds about right.
    Oct 09 2012
    Sounds about right.
    never herd of it before.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by King_ View Post
    Must be a Winnipeg thing haha
    Dec 10 2013
    Borden, Ontario, Canada
    Sounds about right.
    Quote Originally Posted by seanf86 View Post
    It's kind of a big deal in the Canadian army lol
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Oct 30 2009
    Miami, FL
    I hear/use that word at least a few times a week. Get on the bandwagon, it's pretty awesome.
    2018 S5 Coupe - stock for now
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    I hit a curb going up a hill at 60mph at a 45° angle and did not have a subframe alignment issues afterward. I changed the knuckle(and other required stuff) but till this day I regret spending the 120$ for it. I think it would have been fine.
    I personally wouldn't start with the knuckle/horn. Not that anyone is suggesting to.. The lower control arm being bent would make you have positive toe(unless it 'stretched' somehow). If it was me I'd get adjustable control arms. Maybe Mike hood could find someone to sell you just one?... Mayyybe..
    Although messing with the subframe may solve the issue, you're going to have no clue if what you're doing is helping, so you may have to do it 45 times and take it to an alignment shop after each time. It'll make the other side be out of spec, so you'd be trying to move it enough that the good side could be adjusted to fix the problematic side(if problematic side is already adjusted to the max). Idk just seems like you're taking something that's 50% okay and possibly making it be 0%.
    There's some post where I described doing an alignment that is tire specific. It's really easy so if you do go that route you could save some ˘˘. And just get a 'real' alignment once. Could you possibly take a picture with how your off center bolts are at the horn/knuckle/spindle and also on the subframe for curiosities sake?
