Results 1 to 11 of 11
    Registered User Four Rings
    Oct 29 2013
    Q5 3.0T, MK6 GTI S3+, MK6 R S3
    Lebanon, PA
    @@@ APR Front Mount Intercooler for MQB Cars In-Stock at APTuning!!
    The APR Intercooler System is a OEM-location upgrade that dramatically reduces intake air temperature (IAT), minimizes heat soak, and provides increased performance! The system is a direct bolt-on upgrade that requires no trimming and is recommended at every stage of performance.
    Quick Facts:
    • Dramatically lowers intake air temp (IAT) - Increases horsepower while minimizing power-robbing heat soak! Effectiveness tested to over 500 HP! 21 horsepower gain over the factory system!
    • Massive core size - Use of the OEM-location allows for a massive intercooler core. 24.25” x 16.25” x 1.25” – 492.5 in³ – OEM GTI 24.25” x 16.25” x 1.37” – 541.8 in³ – OEM Golf R 24.00” x 16.25” x 2.25” – 877.5 in³ – APR
    • Intercooler installed in the best location for this platform - Utilizes factory air dams for exceptional airflow across the core. 100% compatible with the Adaptive Cruise Control (ACC) system.
    • Highly effective core design - Bar-and-plate core with staggered and louvered fins. Rigorous testing determined core style, fin density, and size. Low pressure drop + highly effective cooling = high performance!
    • Smooth cast end tanks - Engineered for low turbulence/restriction and maximum flow. Organically shaped to promote airflow across entire core. Pressure tested to prevent power robbing boost leaks.
    • No hidden labor costs or permanent modifications - No trimming, cutting, or other costly modification required. No modification to the Adaptive Cruise Control System required. Full directions and APR world-renowned customer support included.
    • Designed by engineers with lasers - With the best equipment and smartest engineers, it just works!
    APR pioneered the OEM-location direct-replacement intercooler system in 2006. Unfortunately, to the untrained eye, many intercooler designs appear the same. However, effectiveness of the system and overall performance are greatly determined by several key metrics. Alloy selection, end tank design, construction type, fin style, fin density and overall core dimensions must be analyzed and balanced accordingly to deliver class-leading performance. While the OEM’s goal is to create a lightweight, easy to manufacture and inexpensive to produce, cross-platform design capable of supporting factory power levels, APR’s intercooler must be capable of supporting more than double the factory output. Achieving this goal took a multi-step approach focused around intercooler core selection, end tank design and install location.
    Core Design:
    The APR Intercooler core is a large bar-and-plate design featuring densely packed staggered and louvered fins. This design offers exceptional cooling while balancing pressure loss across the core, and maintaining critical airflow to the components behind the intercooler system. The core size was appropriately matched to the platform, minimizing pressure drop while leaving adequate space for appropriately designed end tanks. To APR’s mechanical engineering experts, the design represented the ultimate in performance, far exceeding the capabilities of the factory intercooler. To the driver, the result is simple: Repeatable performance, even in the most demanding of situations!
    APR’s Engineers paid close attention to the balance between core effectiveness and pressure drop through the core, core style and fin density. With fin density too low, pressure drop decreases dramatically, but typically results in a core incapable of effectively cooling. Likewise, with fin density too great, pressure drop increases dramatically, resulting in the turbocharger working harder, and hotter, to produce the same level of airflow. By fine tuning this often unseen balancing act, APR’s Engineers were able to maximize performance.
    Intercooler End Tank Design:
    To fully utilize the massive core, APR’s mechanical engineers designed cast aluminum end tanks organically shaped for proper airflow distribution across the entire core. By correctly sizing the intercooler core, end tank design was not sacrificed. The one-piece end tanks are CNC machined to provide a slip resistant mounting surface for hoses, precise integrated mounting surfaces, and perfectly flat connecting surfaces used for TIG welding the tanks to the core. Through proper alignment in welding jigs, each unit is assembled to tight tolerances for a precise and accurate fit.
    APR’s Engineers determined the proper end tank design, for this application, with the help of pressurized CFD flow analysis via the SimuTech Group, and finally through real world testing. During the analysis, the effect of directional vanes were studied to test their ability to aid in airflow distribution. Analysis concluded there was no perceivable benefit on this application as the vanes only added more weight to the system. Real world testing without directional vanes resulted in a +0.5 °C to -0.5 °C temperature spread from the bottom to the top of the core on the outlet side, throughout the various back-to-back tests, further concluding the design maximized cooling effectiveness of the core.
    Intercooler Placement:
    Intercooler placement plays a critical role in overall performance. By utilizing the factory mounting location, APR’s engineers were able to design a core featuring a massive frontal surface area and large core volume, which plays a critical advantage over common short and stubby front mount designs. Utilization of the factory location means the core receives a high volume of pressurized airflow spread across the entire unit thanks to the highly engineered factory air dam system. Furthermore, by keeping the intercooler in the OEM-location and balancing core fin density, the factory air-to-water cooling system is not disrupted, which is ever so critical on this platform due to the use of an integrated cylinder head manifold cooling system.
    The APR intercooler system simply fits, which helps save on hidden labor charges during the time of install. There are no compatibility issues with active cruise control (ACC) systems and the design leaves room for future engine / transmission oil cooling upgrades for track-going customers. The intercooler installs without trimming any air dams, core supports, or more. There’s no drilling, or permanent modifications to the vehicle. Simply follow the included directions and enjoy!
    Testing and Performance:
    Internally APR conducted a multitude of tests while choosing the appropriate intercooler core and end tank design. Thermocouples were placed at the top and bottom of the core to measure cooling effectiveness and cooling distribution across the entire unit. Pressure transducers were placed at the inlet and outlet of the intercooler to determine pressure loss across the various units. With this information, APR’s engineers specified the appropriate intercooler core type, dimensions, cooling fin density and made the necessary design changes to the end tanks to ensure full utilization of the entire core.
    The end result was development of a system that’s much more effective at cooling compared to the factory GTI and factory Golf R intercooler system. Effectiveness is measured as (Intercooler Inlet Temp – Intercooler Outlet Temp) / Intercooler Inlet Temp. The APR Intercooler system’s effectiveness under the most demanding situations was between 82-83% while the factory GTI struggled at 60% and the factory Golf R at 65%.
    Oct 29 2013
    Lebanon, PA
    Boost Hoses also now available!!
    Oct 29 2013
    Lebanon, PA
    Intercoolers are already sold out and currently about a 2 week lead time. Make sure to take advantage of our Holiday Sale discount(good on all parts), hopefully it will ease the pain of waiting for the intercooler. :D
    Special offer good to Audizine members for online orders only!
    • Save 5% on orders of $50 or more by using coupon code - audi5
    • Save 10% on orders of $200 or more by using coupon code - audi10
    Oct 29 2013
    Lebanon, PA
    Still on backorder but will still honor any promos and free shipping on orders placed until the end of the year.
    Oct 29 2013
    Lebanon, PA
    Literally these were selling quicker then we could get more in for almost 2 months. I now have a couple in stock for anyone still looking for one!
    Oct 29 2013
    Lebanon, PA
    Intercoolers are in stock
    Oct 29 2013
    Lebanon, PA
    Tons of orders from over the weekend, finally caught up and everything has been shipped. Keep it up, its much appreciated.
    Oct 29 2013
    Lebanon, PA
    Back up top for Monday.
    We will also be at H20i this weekend in Ocean City Maryland! If you planned to be there and wanted to pick up any parts, simply choose the "Pick up at H20i" option for shipping during checkout.
    Oct 29 2013
    Lebanon, PA
    H20i is this weekend, last chance to get those orders in for delivery at the show!
    We will be there doing UM tunes on site, sale price and free install, as well as making Custom European license plates at the show. Also Free delivery on pretty much any part we have in stock, everything for APR to WRD.
    Simply order online at aptuning.com and choose the "Pickup at H20i" option for shipping!
    Oct 29 2013
    Lebanon, PA
    It's election day, so get out there an vote! Then while you are waiting to see who won, get on your computer or phone and head over to aptuning.com to place an order!
    Use coupon code VOTE2016 for 10% off any order over $100
    Oct 29 2013
    Lebanon, PA
    Black Friday is just a couple days away. Special for Forum members:
    Use coupon code BF2016 to save 10% off any online order. Doesn't matter if its already discounted or on sale, take another 10% off!
