Results 1 to 3 of 3
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    Gunk/Sludge in oil tube connected to valve cover
    I attempted to see if I could access my coolant temp sensor. Since my car been getting 9mpg, and sometimes shows the coolant temp on Cold.
    Took the intake boot off, and removed and OIL hose connected to the passenger valve cover. I found gunked up oil.
    Does anyone know what those hoeses are going to the VCG's? (Right under expansion tank)
    And does anyone know if there is an easier way to get to the coolant temp sensor????
    Heres a pic with bumper off when i did snub.
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    Isn't that the pcv system?
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Aug 30 2015
    Derry NH
    Yes. I've done some research. And it's a breather tube. (So that normal)
    Still can't get to temp sensor. I can get my hand on it. But I won't be able to remove that c clamp
