Results 1 to 8 of 8
    Veteran Member Three Rings IinsureU's Avatar
    Nov 02 2012
    Thousand Oaks, CA
    Headlight Bulb Swap
    Anyone here change there bulbs out to the new Phillips HID Extreme or whatever ? How easy is it to do on a new/2015 Q5 ? Any video would be helpful...
    2019 Q7 3.0 Premium Plus- Glacier White Metallic
    2015 Q5 TDi- Monsoon Gray, MMI, B&O, 20" wheel and Sports Interior Package, Eurocode sways/links and Alu Kreuz
    2014 Audi RS5- Shiraz Red, Black Nappa/Alcantara, MMI, Titanium Pkg, Sports Exhaust, Rear Shade, CF Trim- SOLD
    Veteran Member Three Rings yakev724's Avatar
    Jun 26 2014
    Brooklyn
    Quote Originally Posted by IinsureU View Post
    You'll need to remove the plastic covers on the rear of the lights (the larger ones held in by metal clips). The bulbs are right inside the covers - they're held in, not very tightly, by metal 'finger' clips, just pull and wiggle and it'll come out. Once it's free, disconnect from the cable and remove and replace.
    The pass. side should be easier once you get the airbox out of the way, the driver side has PS reservoir in the way (remove two bolts and you can move it--without disconnecting hoses ofc).
    Hopefully someone can come in with a DIY/photos. Good luck
    Veteran Member Four Rings spijun's Avatar
    Oct 11 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Here:
    http://www.audizine.com/forum/showth...=1#post8925180
    Nov 02 2012
    Thousand Oaks, CA
    Quote Originally Posted by spijun View Post
    The video states 2010-2014 Q5's, wonder if the 2015 is any different and the vehicle shown is a gasser verses mine being a diesel ?!?
    Oct 11 2010
    Sarajevo, BiH
    There is no difference for MY2013-2016, there is no difference petrol or diesel engine
    Established Member Three Rings hurricanes28's Avatar
    Sep 29 2015
    Slingshot pearl black
    Massachusetts
    I would like to know I have the xenon plus headlight and would light to add the xenon plus adaptive. I have a 2015 q5 is this possible
    Oct 11 2010
    Sarajevo, BiH
    Quote Originally Posted by hurricanes28 View Post
    Everything is possible, but whether it's worth it
    Need a new headlight and coding
    Sep 29 2015
    Massachusetts
    I just want to change the whole housing to have it when I make a turn left or right the headlights follow
