    Established Member Two Rings cameron90's Avatar
    Mar 18 2015
    los angeles
    Fault code 18084 epc malfunction
    I do have an xtool vag 401 scanner. I dont seem to have drivability issues. my car Also has an mtm ecu, not sure if it matters. Possibly a throttle body issue.? After seeing how expensive they are holy jesus it worries me thats a huge chunk of money. Some input as to why this code would trigger my epc light to come would be greatly appreciated.
    02 b5 s4
    (Black Betty)
    Dec 14 2008
    Finland
    Most likely TB issue, btdt. Don't necessarily cause any problems and even adaptation works, not sure what causes the code. When you turn on the ignition does the tb make loud rattle.
    2nd hand tb's should be found cheap.
    World's Fastest B5 Avant biturbo Full Weight
    With Race Seats @3800lbs
    TTE950+ 100-200kmh 3,81s
    Mar 18 2015
    los angeles
    I dont hear a rattle, i cleared the code temp. But its only a matter of time till its on again. How would i go about doing the adaption whats the process
    02 b5 s4
    (Black Betty)
    Oct 14 2012
    '86 VW Cabriolet 16v, '76 Honda CB750 Supersport, '80 Kawasaki KZ400
    Goshen, IN
    Quote Originally Posted by cameron90 View Post
    02 b5 s4
    (Black Betty)
    For the xtool. There is a specialty functions menu that can walk you through the adaptation. Or turn the key on and don't touch the throttle pedal for 24 mins.
    Mar 18 2015
    los angeles
    I would hope my battery wouldnt drain itself during this
    02 b5 s4
    (Black Betty)
