Results 1 to 18 of 18
    Established Member Two Rings volkswagensRus's Avatar
    Nov 19 2015
    Buffalo, NY
    whats involved with swapping to Sport Suspension
    I need new struts and I'm finding Sport struts even cheaper than the base ones, but it seems they'd handle better so if it's a simple swap then why not?
    2001 Audi A4 Hibiscus Red Pearl Metallic , quattro, 5spd, Symphony stereo, winter package, 3" 034 catless DP, 2.2" exhaust, white snub nose mount.
    For Sale: 1x oval Borla muffler + piping. 1x rectangular Borla muffler + piping. 1x B5 A4 cat+o2 sensor + wiring.
    FOR SALE: 2 catalytic convertors (one w/ both o2 sensors), Audi B5-a4 cat-back exhaust Borla muffler+resonater
    Established Member Two Rings czum09's Avatar
    Nov 02 2010
    1999 Audi A4
    Cedar Rapids, Iowa
    You just bolt them on and go I believe. You might want the sport springs too.
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    The sport springs is what give you the drop in ride height. And I guess to do it 100% the right way you would have to re torque all the control arm bushings at the new ride height
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    [h
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    He has a 2001. Weren't they all sport suspensions anyways?
    OP, what color are the struts?
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    I believe you should start a single thread for all your questions, nothing wrong with being inquisitive but it's pushing other threads down which could use assistance too.
    Sport struts and springs are decent, coilovers are a good idea if you want lows bit sports are comfortable for a DD.
    Sent from my E6653 using Tapatalk
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    00' Silver B5 1.8TQM
    | Wheels coming | Depo Projector Retrofit (clear lense) | BC Coilovers |
    Kenwood Headunit + 4" F +Jl 6" R + 10" Sub | TFSI Coils |
    | 2.5" turbo back exhaust | K04 RS6 Hybrid Turbo|
    Oct 10 2013
    State College PA
    My 01 was not sport suspension. It may have been the 01.5's tho?
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Quote Originally Posted by redline380 View Post
    No.
    Jul 27 2011
    IN
    Quote Originally Posted by czum09 View Post
    Quote Originally Posted by Davdraco1 View Post
    These above plus you need new bump stops too(or cut the existing ones).
    Ideally speaking you need the 29mm sports sway bar also but it is not necessary..
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    my 01 has sport suspension you can also find out from your door tag and owners manual for your cars equipment if not alraedy modified. sport suspension is typically red. my car came with the setup like that. you do need to retorque everything though to do it all correctly, otherwise you will wear out your control arms pretty fast. also the one thing i havent seen mentioned. is your car a 1.8t or a 2.8 the springs are for the engine size you have. if you fit 2.8 springs on your 1.8t you'll have positive rake and your car will be too high in the front. so match your springs to your engine size, but i think only 1.8ts had red shocks anyways, ive never seen a 2.8 with them, but i could be wrong on that.
    Nov 19 2015
    Buffalo, NY
    Sorry for the threads guys, I bought a car knowing that it needed some work, and I"m crunching to get this thing going before the snow really flies.
    I dont think it's sport suspension stock. The rears were swapped to KYB garbage and I'm not sure what color the fronts are, I'll go look. Dont believe they are red though.
    I'm NOT looking to go lower; we average 171" of snow here every year which means the ground clearance is much appreciated.
    If there is a ton involved to go to sport suspension, I wont do it. I found some Bilstein OEM style shocks for a GOOD price.... half the price of the HD's. I think I will end up going that route.
    Oct 10 2013
    State College PA
    I think sport suspension is around a 20mm drop compared to stock, that's almost an inch. And on our cars that's over 10% in drop.
    Nov 19 2015
    Buffalo, NY
    Ya I'm not looking for any more low. I'm pretty sure I"m going with Bilstein Touring struts. Will do more research but for the price and the for the quality I think that's what I will end up doing. I don't need the a4 road-race ready, as I plan for it to be my DD. Comfort + handling is key, which I dont believe the Sports or HD's will give me.
    Nov 02 2010
    1999 Audi A4
    Cedar Rapids, Iowa
    You'll be fine. It's not "low" by any means. With proper tires, you'll have plenty of clearance.
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    Quote Originally Posted by RagtagXMASTER View Post
    2.8 cars can have red sport suspension, too. I sold mine to a guy who was doing the swap when I bought Bilstein Sports and H&R Springs.
    Bilstein comforts are "10% stiffer than stock" IIRC, whatever that means.
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    Ive never seem a 2.8 with the sport suspension then again ive only seen a handful of 2.8s. Thanks for the clarification
    Jun 10 2010
    I have a set of sport shocks (three good, one leaking) that I'll sell for $free.99. Just pay shipping.
    Nov 19 2015
    Buffalo, NY
    ^Ah thank you for the offer, but I already have some Bilsteins on teh way :)
