2002 A6 4.2 with 6 speed swap $6800 OBO
2002 A6, with the 4.2 V8 (widebody car), and 6 speed manual transmission swap completed. Car is located in the Twin Cities, MN area.
Recently installed lower mileage engine. Car runs and drives like new, no noises, no leaks/etc. All swap issues have been sorted out, ECU flashing, cruise control/ABS/Traction control/etc works great.
Chassis mileage: 184,700
Engine mileage: 120,000
Drivetrain mileage: 130,000
Engine/exhaust:
New (120k miles) engine installed recently due to noise in valvetrain of previous engine.
SAI delete
Cats deleted (open exhaust all the way to the mufflers)
Billet oil cooler coolant pipe (Bufkin pipe) installed 15k miles ago (this is becoming necessary on all older 4.2's, if you are buying one without it, plan on doing this, as the stock plastic one will crack and leak coolant -- fairly labor intensive fix)
Suspension:
18x8.5 VMR wheels, with only 3,000 miles on tires ($1600)
H&R lowering springs ($250)
Moog adjustable upper control arms (installed 6,000 miles ago) ($300)
Drivetrain:
6 speed swap -- purchased 02 A6 2.7T 6 speed donor car, and swapped in the transmission, front axles, driveshaft, rear differential, pedal assembly ($2500)
New B7 RS4 clutch/pressure plate ($600)
Flywheel machined ($100)
New slave cylinder ($60)
Electronics/Interior:
Coding performed on the ECM, ABS, and TCM to make the 6 speed work. S6 calibration installed, ABS coded, etc
Pioneer touchscreen DVD player ($300)
Interior in great shape, and has the sport seats which have awesome bolstering. Heated front and rear seats.
Recent Maintenance:
Current mileage: 184,700 (still driving occasionally and going up slightly)
184,400 -- 120k engine installed
176,000 -- 6 speed swap
176,000 -- Moog adjustable upper control arms, alignment performed
174,000 -- Billet oil cooler tube installed
172,000 -- Timing belt, tensioner, water pump, crank seal, cam seals, valve cover gaskets, etc ($600)
- No current issues at all with the car. Runs/drives great, ready to go for many miles. $6800 or best offer
List Date: 12/2/2015
For more info, click here to view the original listing: 2002 A6 4.2 with 6 speed swap $6800 OBO
This item is no longer available.
