Based on your pictures I would second T-Stat & J plug. I just replaced mine again with a refresh kit from ECS. Thermostat was sticking open sometimes and car would take along time to get up to temps, or just stay around the 1/4 mark on the gauge. I had small leak in the same location. When I started tearing it down I found the old plastic J plug was cracked in half and leaking.
Coolant flange is located on the rear of the engine so that doesn't look like the source in your pics. Could also have air in the system if you have no heat, but my money is on a sticking T-stat.
If you really want to nail down the source of the leak before spending money on parts I would recommend getting a cheap UV dye kit. I added it to the coolant, drove for a few days then inspected with a UV flashlight. Made it easy to confirm where the leak was coming from.
as APR_Fast said there are a lot of treads on the subject to help you figure it out.
Just make sure it doesn't get too hot. . . . if the gauge creeps up above noraml tell your sister to pull over and stop driving immediately. First time I had this same issue it was fine until I got 400 miles from home then t-stat got stuck in the closed position, over heated my engine and resulted in $2200 with of repairs.
