Results 1 to 27 of 27
    Veteran Member Three Rings Audimilo's Avatar
    Apr 19 2014
    CO
    FrankenTurbo F21 Longevity update
    I just ticked over 20,000 miles on my F21's, and as promised here's an update:
    First off, let me toss this out there that I have no affiliation with Frankenturbo or Doug, I'm just a customer who went with the turbos I found best suited to my needs at that time. (daily driver car), stock block.
    I'm on a 91oct Daz tune, peaking at 25, holding 24 psi on a daily driven Avant, (273,000 miles).
    The car is my daily. as suggested, I drive it daily. I commute a lot: about ~ 500 miles a week.
    One thing i am religious about is proper warm up. The car never sees over 3k rpm and Zero boost till the Oil temperature comes up. that is CRUCIAL for turbo longevity. even then i ease into the boost for a couple of gears before it sees WOT. with that said, the car sees 24psi every single day.
    to date, ive got no issues. I have been hearing a very very lightly increased turbo noise during warm up, but after warmed up, no issues. Could be the winter temps.
    Tested my wastegates prior to install, checked all fasteners etc, all checked out good.
    broke the turbos in so to speak with very mild driving and minimal to no boost through multiple heat cycles and 1000 miles (new clutch installed at that time too) during that time the coolant banjos weeped slightly, but eventually the G12 did what it does and they sealed up.
    oil changed every 3,000 miles.
    my k03's were still going at 253,000 miles when i swapped, they were noisy in the morning and leaked a bit, but still hit max boost (MTM stage 2 chip on those)
    just fyi, for those who care.
    cheers.
    Jun 08 2014
    Vancouver, Washington
    This makes me feel much better about running my stage 2 tune on K03's. I've started getting into the habit of warming the car before boosting but I shall institute your couple other warm up techniques before hitting 20psi :P The turbos had minimal shaft play 10k ago so I want to keep these alive until I can 6mt swap and do bigger turbos. Also, at 253k, how did your turbos look when you swapped to F21's?
    May 30 2015
    canada
    good info, thx for sharing. Threads like this will help me make my decision on turbos in the future a bit easier, ive been telling myself to just stick with pj k04 when the time comes but i will gladly go with a set of turbos that cost less if they hold up the same as the borgwarners. it seems the average k03 turbos can last anywhere from 50k - 250k miles, i would hope k04 style can last the same if taken care of as well.
    Apr 19 2014
    CO
    Quote Originally Posted by MarlinFoundNemo View Post
    ehhh they were actually better than i thought. they made a pretty audible "wooooooooooooooooooo" while warming up, but once to temp were fine. they leaked a bit of oil, but again, hit requested boost, and did fine. a bit of shaft play, but less than one would expect. nothing that would be cause for concern.
    so, after 253k miles, they were dirty, oily, noisy, but functional, and did the job. i just couldnt leave them alone ...
    Apr 19 2014
    CO
    Quote Originally Posted by reverse.rake View Post
    id strongly remind anyone that nobody's done 250k on a F21 yet. Borgs have done that a few times on other cars. As far as i know im one of the higher mileage F21 sets out there running, would love to hear some more feedback from other users.
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    I've got a set that were abused for 20k. Been on my car for a little over 7k. 25psi to redline currently.
    Stock engine with some rods tossed in. 11.25@132mph.
    Apr 19 2014
    CO
    ^ nice! thanks for chiming in. thats 2 sets at 20,000 miles +
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    Have most of you guys that have f21's also experienced standard k04's and is so do they drive pretty much the same? I'd guess a tiny bit slower spool and better up top? Any more people running the newer mixed flow units?
    Aug 04 2013
    Pennsylvania
    I'm at 25k at the moment! 27psi to redline and I usually indulge in at least a quick pull once a day. I'm the same way about the warmup. I drive like a grandma until oil hits temp lol. Mobil 1 0w 40 every 5k
    Apr 19 2014
    CO
    Quote Originally Posted by APR-S4 View Post
    good call.
    slow ride- to answer your question: no i do not have any K04 experience, i went straight to F21's from K03's
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by Audimilo View Post
    That's exactly how mine are, but not super audible. Definitely there though, thanks for the updated. Yikes you commute a lot!
    2024 M3 Comp xDrive
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    You guys need to catch up. I'm almost to 80k miles on BW k04's ~26psi.
    Nov 02 2014
    Winchester, VA
    ^ Makes my want to crank my f21's some more....
    Maybe by the end of 2016 and I've gotten the wife a new ride/stolen her Saab for DD.
    Senior Member Two Rings acoleman's Avatar
    Feb 07 2011
    Bismarck, ND
    I'm at 40k still going strong, no noise. Some of the original FTs installed in 2011. Like the OP, proper warm up and cool downs. 25 psi EPL tune.
    Apr 19 2014
    CO
    Quote Originally Posted by Peter1.8t View Post
    Properly cared for Borgs should last a long, long time. I had 250,000 on my borgs... maybe YOU need to catch up ;)
    Quote Originally Posted by acoleman View Post
    Excellent to hear.
    Veteran Member Three Rings Audi9's Avatar
    Jul 20 2014
    B5 S4, 8V A3, 8V.5 RS3
    San Antonio, TX
    Cool to see a long term update
    Dec 03 2009
    PNW, Washington
    Lol I couldn't wait that long for them to die, so I opted to upgrade early. Still have my k03's sitting in a box in the garage, great condition.
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    15k+ miles here, no turbo issues at all, running 3F tune 21psi.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Apr 19 2014
    CO
    Awesome. thanks for chiming in fellas.
    looks to be like most folks are having good longevity with the F21's thus far. I gotta be honest.. what a FUN daily driver the F21 setup is!!
    Sep 23 2007
    Close to 35k on mine no noise that I'm aware of. 25psi everytime I drive it. Just wish they spooled a bit quicker.
    Nov 02 2014
    Winchester, VA
    Quote Originally Posted by jturnbull View Post
    How late do yours spool? I just pulled up a 3rd gear log, starting at 2k, and hit 20psi at 3100rpm. Granted, I don't reach full boost until 3rd gear, but that's because the car is just stupid quick through 1st and 2nd. 1st and 2nd are both right around 22psi, and 3rd on up peaks 25.
    Apr 20 2005
    New Hartford, IA
    That's not bad for spool, what do you think a k04 would be 300rpm sooner?
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Around 25K on mine, and I always boost around town / on the highway. No issues here, only at 22PSI though. 24 on E85
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Jun 14 2007
    2000 S4
    Connecticut
    FYI - you can chalk that up to DVs in the cold temps/winter. What type of DVs are you running?
    Quote Originally Posted by slow ride View Post
    You have it right.. I have K04s, and have been in/logged over a dozen S4s running FrankenTurbos and I would say yes to slightly slower spool (could even be due to hardware diffs.. it was maybe 100rpm) and then up top they are slightly better at holding boost and continuing to make power.
    Jan 31 2008
    I had K04's in my old S4 with just about the same setup as my F21 car now, not much of a difference, maybe a tiny slower spool but I wouldn't say that is very noticeable. Still perky around town.
    My Meth K04 car and Non-Meth F21 car run the same FATS. (different tunes, EPL Meth vs Daz F21) - I also had a Lee tune on the K04 car, ran the same as EPL.
    Apr 20 2005
    New Hartford, IA
    Thanks guys, good info, sorry to bore the rest of you haha. I just want my S4 setup to spool slightly better than the twin 6265's on the vette, but that car is almost worthless under 100.
    02' Tundra
    Jan 31 2008
    I saw logs of the SRM K04's and was pretty impressed, I wouldn't rule those out - I would love to see them VS the F21 mixed flow..
