So i decided to actually drive to work today since there was road closures towards where i park for the train. On the way there, after leaving a light and then coming to a stop at the next time the following symptoms started:
Idle is about normal at 850 or so, but fluctuates slightly.
Car pulses at 1 second intervals
Vacuum reading at about 15 in/hg
No CEL
When driving the car is fine, hits boost, etc.
If i give it gas while stopped symptoms go away, revs fine, no misfires.
Once i turned the car off and turned it back on, it idled a little rougher and hung at like 1100 till it gave it some gas then it eventually dropped down to normal and gave the same symptoms again as above.
If i give it gas and let off the vacuum goes to 20-21, then settles back down to 15
Car is stock, changed plugs to NGK BKR7EIX about 10k miles ago. Has only a test pipe, r8 coils, BFI CC, stock tune.
Any suggestions? Tried to check under the hood but i had to run in to work so shes in the parking lot now, hopefully she won't leave me stranded lol.
Read through other threads but symptoms can be different for others. Just posting a thread since i don't get out of work till 7, by the time i get it back to the shop i won't be able to buy any parts really.
I'm thinking maybe N80?
