Results 1 to 23 of 23
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    2-pieces Front rotor Choices for our S4
    Hello,
    I am searching for a good 2 pieces rotor for my 2013 S4.
    I have the Q5 brembo calipers upgrade, and just cracked my Zimmermann Cross-drilled rotors.
    I would like a plain rotor, or slotted, that could bring a little more cooling, by directionnal veins.
    But no more drilled rotor...
    So, here what i found:
    - JHM: it seems that they are dedicated to weight loss reduction and are verry thin. I have seen reports of rotors cracks du to this.
    - Girodisc : seems a good possibility
    - APIKOL: it's my favorite for the moment, since i would prefer a plain surface rotor vs slotted.
    Are there other possibilities to consider ?
    What are your feedback about these, guys ? Especially APIKOL which seems to be verry few represented?
    I would prefer to not go in the "get a BBK" discussion, I track my car "gently" 2-3 times a year and don't want to go further than this upgrade. (Q5 calipers + 2 pieces rotor)
    Thanks in advance,
    Best regards,
    Mat
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    We've installed a fair amount of JHM rotors - they're much lighter, and we haven't seen a set that has cracked or anything.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    I'm running ECS Tuning's 2 piece rotors. I think they are actually lighter than JHM's (correct me if I'm wrong) and less expensive. - https://www.ecstuning.com/Audi-B8_S4...ors/ES2602983/
    They also sell floating wave rotors that should weigh even less - https://www.ecstuning.com/Audi-B8_S4...ors/ES2681113/ - these should allow for more even application of force from the calipers...
    They have matching for rears too obviously...
    Jan 20 2016
    World
    Hello Mat,
    so what did you get as a replacement of you Zimmerman?
    Because I was looking to buy myself some zimmerman's.
    Jun 14 2015
    FRANCE
    Quote Originally Posted by dResign View Post
    Hello Mat,
    Hello !
    I don't want to say Zimmerman are not good. I fact i am convinced that it is a verry good brand.
    I just made the mistake to get some X-drilled rotors and go to track with them... X-drilled are too weak and prone to crack for track use.
    If you get them for the street, it will be great.
    Btw, i ordered Girodisc Front rotors and put them on the car in february
    BR
    Mat
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Nov 28 2015
    Montreal, QC
    look like a serious rotor !! have you noticed quicker acceleration due to the 6lbs shaving ?
    Jun 12 2015
    CA
    Quote Originally Posted by MrFunk View Post
    JHM: 15.75
    ECS wave: 17.8
    Girodisc: 18.4
    ECS: 18.45
    Oct 02 2006
    Wadsworth,OH
    We have not had much if any negative feed back in regards to our ECS 2-piece rotors and them being drilled.
    Jason
    Nov 28 2015
    Montreal, QC
    Jason
    heard a few comment about them having poor braking in winter/slush environnement.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by waxxonMTL View Post
    Doubt that's related to the rotors and more so the pad choice.
    Jason
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    At this moment in time we are liking the Girodisc/Apikol route. StopTech has not come out with anything as part of their ARK program that we have been trying to help kick start. The price is up there for the Girodisc/Apikol but the quality is unsurpassed at this moment for the options available.
    Mar 26 2010
    US
    The slots in the Girodisc rotors are nice, rotors to be seem well built, they work fiine, but they do seem heavy, though.
    BMW M3 Competition X-drive
    Jun 12 2015
    CA
    Quote Originally Posted by Excelerate Rep View Post
    Do you know if Girodisc's B8 RS5 rotor fits on our platform?
    Established Member Two Rings pcardenas's Avatar
    Sep 04 2014
    S4 B8, Audi Q7
    México
    Mat,
    have you taken your car to Track Day with your brembo (sq5) Calipers??? How better is the brembo calipers than stock????
    Im looking for that option but dont know if is money worth?
    Jun 14 2015
    FRANCE
    Quote Originally Posted by pcardenas View Post
    Mat,
    Hello !
    The upgrade is with Q5 calipers (4 pots fixed), whereas the SQ5 has 2 pistons (and is floating).
    So, i have taken the car once on track with those calipers. I can not aswer verry clearly since i had a little problem with brake fluid bubbles (entrapped in the ABS block and realeased at the first ABS triggering).
    The pedal was verry low...
    Since it is cleared, but i did not return to track and did not have agressive driving...
    But i have to say that modulation is good and the pedal feels solid.
    I think that the first feature of these calipers is to be verry simple for pads swap and allows a hudge choice of pads coumpounds !!
    I will do a feed back (with Girodisc rotor as well) in mid march after my next scheduled track day.
    See you !!
    BR
    Mat
    Sep 12 2014
    eGolf
    Pasadena, CA
    Resurrecting an old thread because my brake pad indicator has come on at 29,000 miles! Absurdly low mileage in my opinion but the dealer did warn me the light would be on soon. Definitely doing the Q5 caliper upgrade and am considering a rotor upgrade. Any in person experience to share on our 2-piece rotor options in the past year? Apikols look beefier than the others and I do like the lack of slots. JHM's are the best price by far but are they too thin? Are the Girodiscs's with the spring washers worth the price? Any input would be appreciated. Maybe not worth the cost and just go with regular rotors? On a related note: Anyone try those new Neuspeed calipers? They look pretty sweet but I'm not in position to pay the extra cost over the Q5 upgrade.
    Nov 28 2015
    Montreal, QC
    Quote Originally Posted by rlfletch View Post
    I'm still thinking about which rotor I will buy.
    JHM is out of the equation ; look at their thread about bad quality cat-delete. Too many complains, I don't trust these rotor.
    Apikol / Girodisc ; look the same to me except for the slot, same price, floating design, same weight too. Somehow I prefer the girodisc reputation, but i prefer non-slot. Both at 800$ tho... yikes!
    Only reason I would want 2 piece is weight saving for quicker acceleration. however, I couldn't find any review saying they clearly felt an improvement in this area.. so decided to go one piece.
    Brembo JUST CAME OUT, fresh of the baker, 2 new rotor for the Q5/S4.. I read the brochure and they look the sh*t.. Unless something came up within the next month, I will go this route. I mean.. it's brembo and it's a ''sport'' rotor which means it has enhancement over a oem replica.
    or theres the slotted Stoptech.
    both rotor are about 300$, the 500$ saving can go toward other mods or.. the wife :P
    S4 B8.5 no track, just enjoying spirited driving.
    Sep 12 2014
    eGolf
    Pasadena, CA
    You have a link for those brembo rotors?
    Jan 20 2016
    World
    https://www.bremboparts.com/europe/e...ro/000030005-1
    09.B039.10 09.B039.11 (+ UV Coating)
    09.B970.11
    09.B039.1X
    09.B970.11 is the one I will buy.
    Jan 20 2016
    World
    Just had a chat with Brembo Italy.
    They will release the 09.B040.1X in Q2 of 2017
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Wouldn't 09.B970.11 be better as it uses pillars instead of veins/fins for cooling ??
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Jan 20 2016
    World
    Correct.
    I am using the 09.B970.11 on my car.
    Just wanted to share the information i've got :)
    Nov 28 2015
    Montreal, QC
    thanks for the info.. i just wish now they would make a 2 piece version before I'm due for new rotor loL!
