Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 176
  1. #81
    Mar 24 2013
    Oakdale, CT
    I decided to keep them because I intend to drive this thing everyday, and the increased vibrations would probably get old. I have stiffer drivetrain mounts also, so that isn't helping. I have also never really seen an enthusiast owned (aka well maintained) motor have a balance shaft issue. I have them in my current motor and have consistently revved to 7200 rpm with no issues. That particular set of balance shafts has 152k miles on it at this point.
    I will also be using the updated oil pickup that has an alternate suction tube on the side. In the event the strainer becomes clogged, this tube opens to prevent a loss of oil pressure and can save the motor. I think this may be an underlying root cause of a lot of balance shaft failures. Low oil pressure going to steel shafts spinning inside an aluminum casting is a good recipe for seizure.
    -Adam
  2. #82
    Jun 27 2011
    I think that's a good thought on what causes these failures. The 2.0t uses basically the same oil pan and pickup and pump mechanism as the 1.8t and you see very few failures because I think it's a bit more tolerant of low pressure. With the b7 it seems by the time you have low enough pressure to trigger the idiot light, you're already fucked and the balance shafts are a minute away from seizing anyway. And when they seize it causes a shitload of cascading damage.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  3. #83
    Nov 15 2011
    Montreal | I sell in USD
    I have 034 mounts and tbh I dont (really) have more vibration after the 06A oil pump conversion. Didnt even know there was a revised pick up tube, I'm curious could you share the part number?
    *****I sell in USD*****
  4. #84
    Mar 24 2013
    Oakdale, CT
    Updated part: 06F115251B
    Explained in this thread:
    http://www.audi-sport.net/xf/threads...cation.227639/
    -Adam
  5. #85
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    This is one reason why the previous owner of my b7 did a oil flush with oil engine cleaner at every 5000 miles.
    Plus the magnetic oil plug. .
    And of curse a good quality syntec oil. I use the liqui moly leichtlauf oil blend (well semi syn)
    Let say I want to put the upgraded oil pickup line, how much time it takes in the average?
    Is there any chance that a 2008 b7 got the upgraded pipe?
  6. #86
    Jun 27 2011
    Whoa I never knew about that. Looks like whenever I rebuild my engine that new pickup is going in for sure.
    -CP
    2017 Q7 3.0t
  7. #87
    Jun 27 2011
    Quote Originally Posted by oVeRdOsE View Post
    Highly doubtful the 2008s have that pickup.
    Also in most cases the pickup is clogged by rtv or plastic parts, not always sludge so oil treatments (like AutoRX) or something shouldn't always do much to solve the problem.
    -CP
    2017 Q7 3.0t
  8. #88
    Jul 01 2015
    Mtl
    yes, probably. good point.
    I need to take a look soon.
  9. #89
    Mar 24 2013
    Oakdale, CT
    Also by water in the oil freezing in cold climates.
    -Adam
  10. #90
    Jun 17 2013
    jersey city nj
  11. #91
    Jul 01 2015
    Mtl
    Quote Originally Posted by vce1232000 View Post
    indeed. -21°C (real) this morning here.
  12. #92
    Mar 24 2013
    Oakdale, CT
    A wise man told me that
    -Adam
  13. #93
    Dec 23 2011
    Tons of good info in this thread. Glad to see things coming back together.
  14. #94
    Aug 04 2015
    Kansas City
    That updated oil pickup tube is awesome. I'll add it to my list of things to buy. Anything that can help prevent catastrophic engine failure is a good thing.
  15. #95
    Mar 24 2013
    Oakdale, CT
    Updates in post #75 to show you how to break tools.
    -Adam
  16. #96
    Dec 23 2011
    That crank bolt is a bitch to torque properly. To get the timing gear on easily I put it in the oven at 300 degrees for 20 minutes and it slid on easily.
  17. #97
    Jun 27 2011
    Stop breaking your tools rookie!
    -CP
    2017 Q7 3.0t
  18. #98
    Nov 15 2011
    Now, using a breaker bar & a pipe, proceed to break your tools.
    Made me chuckle at my desk
  19. #99
    Jun 27 2011
    So you want to build your engine… Well, here’s how to do it.
    Saw a few large plumes of smoke emanate from my tailpipe today driving home. Thanked the lord baby Jesus that this thread exists and at some point I can print it out, bind it, and make a guide book out of it for my eventual engine rebuild.
    -CP
    2017 Q7 3.0t
  20. #100
    Mar 24 2013
    Oakdale, CT
    I have it all saved in a word file if you want it. It might be easier to print that way.
    Edit: Also updated to show the final steps of assembly.
    -Adam
  21. #101
    Senior Member Two Rings Muggerrudd's Avatar
    Apr 01 2014
    Cleveland Ohio
    update?
    2007 A4 2.0T QUATTRO
  22. #102
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Muggerrudd View Post
    update?
    It's done. All the latest updates are in the string of posts that start at #74. I haven't yet put it in the car though, if that's what you're asking. I need a good chunk of time off work and without having to watch kids to pull that off. Maybe V-day weekend...
    -Adam
  23. #103
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Quick question, how are you planning to break in the motor? Any specific method?
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
  24. #104
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Denio24 View Post
    Initial oil fill will be a non-detergent, non-synthetic SAE 30 oil. Brand depends on what I find. On initial start, I will only let it run for a few seconds just to make sure everything is hunky dory. Then once I finish putting everything back together, I'll go out and drive the car trying to avoid constant rpms. I'll try to keep a relatively high load on the engine when possible while avoiding the upper rpm range. You also want to do a lot of engine braking on decel. I'll put 50-100 miles on the car driving like this and then change the oil and filter. I'll go with a conventional 5w-30 for this one simply because it's cheap. Drive the car normally for the next 300-400 miles, then change the oil and filter again. At this point, go with whatever synthetic you want to run, I'll be running Rotella T6 5w-40 and going to 5k change intervals.
    I'll also be breaking in my new JHM stage 3 clutch at the same time, so I won't be able to beat on it for a couple weeks.
    -Adam
  25. #105
    Jan 23 2013
    Chicago
    Thanks for this advice, ill be building my engine this year as well so this will come in handy.
  26. #106
    Jun 27 2011
    Might not be a bad idea to put a quick legend in the first post or have links connecting the shards of the diy. You know, to help nooblets like myself navigate the thread.
    -CP
    2017 Q7 3.0t
  27. #107
    Mar 24 2013
    Oakdale, CT
    There are only 2 chunks to the DIY. At the end of the first chunk, it tells you to go to post 74.
    -Adam
  28. #108
    Jun 27 2011
    NO!!!!
    -CP
    2017 Q7 3.0t
  29. #109
    Mar 24 2013
    Oakdale, CT
    NO!!!!
    Yes?
    Side note: Holy shit at your post count man! I thought I wasted too much time on this forum.
    -Adam
  30. #110
    Jun 27 2011
    Yes?
    I have no life....
    90% of it is in WinterMode...
    -CP
    2017 Q7 3.0t
  31. #111
    Mar 24 2013
    Oakdale, CT
    I have no life....
    I don't make it to the B6 section very often. Normally just to check out the build threads after I feel like I've read everything in the B7 section. On that note, I wonder if Doctor has any updates since I last looked...
    -Adam
  32. #112
    Mar 24 2013
    Oakdale, CT
    Sad day. Doc shelved the 2JZ and is going back to the 1.8T.
    -Adam
  33. #113
    May 31 2015
    2017 Mazda CX-5 Touring
    Twin Cities, MN
    Awesome thread Aluthman, your knowledge is always fun to read! Couldn't help but notice that the tools you broke were Harbor Freight brand haha. I also snapped a drive adapter from there last night pulling my wheels off to do the brakes. Lifetime warranty my ass!!! Luckily had my dad's Ram on backup to go get some real impact grade stuff
    '06 A4 Avant 2.0TQM S-Line Brilliant Red- | JHM High Flow Cat | Bosal Center exhaust | 034 Snub, motor, & trans mounts | 034 Spherical Front Sway End Links | 034 Street Density Control Arms | Meyle HD tie rods | ST coilovers | 750# Hyperco rear springs | Bilstein B8 rear shocks | S4 rear brake swap | Mk2 TT Turbines w/Pilot Sport AS3 | Blizzaks for snow
    -Plans: 155k and going...
  34. #114
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Tsinsta93 View Post
    The tools I broke were Craftsman. I haven't broken a HF tool yet. To be fair, they wouldn't have broken if I wasn't using a 3 ft. cheater pipe.
    -Adam
  35. #115
    Senior Member Three Rings Van Black's Avatar
    Sep 07 2015
    Romania
    Do you have any upgrades on the valves or rockers? I've read somewhere that RPMs over 7k cause the rocker arms to break...
  36. #116
    May 31 2015
    Twin Cities, MN
    Sure enough, I saw Pittsburch on the socket but that extension was Craftsman. The 3ft cheater definitely increases the abuse. Still hoping to put it in this month and see if it solves the oil problem to your liking?
  37. #117
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by Van Black View Post
    My head already has Ferrea springs, valves, and retainers. The rockers and lifters are stock. IIRC, the stock spring retainers were the weak link at high rpm.
    I think I'm going to install it on V-day weekend.
    -Adam
  38. #118
    Sep 07 2015
    Romania
    So it's the retainer that snaps?
    http://www.audizine.com/forum/showth...e-Build-Thread
    That's where I've read about rockers failing. It's something I keep in mind because I've got a very
    high rev style of driving sometimes.
  39. #119
    Mar 24 2013
    Oakdale, CT
    I've never actually talked to anyone that has had a valvetrain failure due to stock lifters/rocks/retainers. It's all been the "I know a guy whos brother's girlfriends cousin had it happen" type stories , so take it with a grain of salt.
    -Adam
  40. #120
    Jun 27 2011
    Yea. And unless you're revving the ever living nuts off the valve train I don't ever expect any failure there aside from valves burning up due to carbon buildup.
    -CP
    2017 Q7 3.0t
