Results 1 to 6 of 6
    Active Member Two Rings Phaxmohdem's Avatar
    Nov 17 2015
    Kansas City, MO
    Anyone with a VAG-COM bored and want to take some trans temp readings?
    Has anyone with a legit VAG-COM and an IR thermometer ever made a table of what the VAG temperature reading is vs. IR thermometer at different points on the trans and fill pan as the car warms up?
    Edit: Ambient/room temp would be good to know as well.
    I'm feeling ballsy and have the stuff in hand to a CVT trans fluid and pan filter change, but my ghetto VAG code scanner tool doesn't read trans temps... just error codes. I do have an IR thermometer, though.
    Another Edit: If this is a stupid idea... can one rent a VAG-COM for a day for this purpose?
    Daily Driver: 2008 A4 S-Line, FWD Multitronic, 110K mi -- Bone stock (Except for 034 Street Density motor mounts)
    Backup: Mountain bike
    Oct 16 2008
    South Florida - Ft Lauderdale
    VFIZ does give you live tranny temp fluid as well as TCM temperature
    Phil
    Feb 24 2004
    Minneapolis
    I did a ATF change on my 96 A4 before I had a VCDS (a.k.a. VAG-COM). I bought a cheap outdoor/indoor digital thermometer. I filled the trans cold, snaked the outside sensor into the trans fluid, ran through the gears and waited for the fluid to get to 35 C. Worked great!
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Nov 17 2015
    Kansas City, MO
    Dang, VFIZ looks pretty slick. $250, though... and I don't have the pretty full color dash display :(
    Nov 17 2015
    Kansas City, MO
    Quote Originally Posted by mtroxel View Post
    That's a good idea... this bad boy looks like it might be just the ticket: Wally World Special
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Phaxmohdem View Post
    Good for you. I paid $12 for mine at Home Depot.
