Originally Posted by
Atzek333
Hey guys, in germany many of the tuners are saying that 550nm is the max. torque for the DL501 Stronik
some tuners have tuned there s4 over 520hp and 620nm with stronic whats really high
The spec of the DL501-7Q 0B5 is 550Nm at 9000rpm. Now in my mind that should mean that at lower revs it should be able to handle more torque? Maybe someone with some proper mechanical knowledge could confirm or contradict?
However isn't it also true that the maximum torque is limited in the ECU?
In the UK a company called MRC gets the best results. On their test mule they got 500PS and 600Nm and that was with a manual gearbox. On customer s-tronic cars they regularly measure around 470-480PS and 590-600Nm. That's with pulley, remap and the usual air intake improvements, and of course the best fuel which is nominally 99 RON (although its almost impossible to be 100% sure of octane in the UK as we only regulate for 95 RON and 97 RON).
Anyway there are enough stage 2 S4s and S5s about to suggest that the s-tronic can take 600Nm. It does seem that s-tronic failures are predominantly in the earliest cars, with unturned cars failing as well as tuned cars.
