Results 1 to 10 of 10
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Are "V" rated tires OK for Audi?
    I got some Blizzack snow tires last year for snowboarding trips to the local hills. I didnt end up installing them last year as our winters here in So Cal were basically non-existant!
    This year it looks like they'll be needed.
    I noticed that they were / are V rated---is this OK for our cars? Im not sure what my old ones were---letter rating wise--I dont remember them being a V though?
    What letter can "we go down to" to be safe?
    Also, these seem like a softer rubber compound than the others I had. Might this be due to a different rating system?
    Jun 17 2013
    jersey city nj
    V rated tires can sustain speeds up to 149 mph. Z rated tires can sustain speeds 149 mph and higher. Blizzacks are snow tires with soft rubber compounds made for traction in snow and ice that are V rated. Unless your ing above 149 mph in the snow and ice, youll be with the V rated Blizzacks
    Jun 15 2011
    Exiled.......
    Ok that's what I figured--the tires I bought from a lady came off a significantly less powerful and less handling car----just checking.
    Makes sense after I read about it.
    What you do want to be careful with is the two digits beside the v. That is the load rating. Our oem tires are 94. You can usually stray a bit in either direction but keep that in mind.
    Sent from my m8 using Tapatalk
    Using Tapatalk
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by gavin_j View Post
    I always wundered what the 94 was . Now I know.. learning sumthin new everyday
    Using Tapatalk
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Another tidbit of info that a lot of people don't know is that tires have production dates on them.
    http://www.tirerack.com/tires/tirete....jsp?techid=11
    Senior Member Two Rings UberTeile's Avatar
    Sep 01 2010
    Southeastern, PA
    All regular B7s(2.0T & 3.2) are spec'd for standard load tires(94) while S4s require extra load rated tires(97 or higher). You can put extra load tires on any B7 but you shouldn't put standard load tires on an S4.
    ll Audi Sport "Vorsprung Durch Technik"
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by B-Time View Post
    You always want to check the production date prior to buying used tires. I actually like to check new tires as well. They're good for ~6 years IIRC. The rubber will deteriorate.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Yes V rated tires are OK...In fact, they are the "average" I would say.
    I made the mistake of buying H rated summer tires Not end of the world but it basically means I can drive faster on my 17" winter tires (V rated) than my 18" summer tires...
    So even though my car can go faster than 210km/h, my tires are the weakest link
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
