Results 1 to 7 of 7
    Nov 21 2015
    Galway, Ireland
    Lambada spacer for diy piggy pipes ?
    Apparently i need four of these two per side, anyone have a link to where i can get some or will a universal angled one work ?
    Also been getting a burning smell in cabin along with the usual high oil consumption, does this point towards rocker cover gasket ?
    Thanks folks
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Are you a dancer? Perhaps you meant Lambda?
    Old Geezer, formerly known as Stud Muffin
    Nov 21 2015
    Galway, Ireland
    La couca racha
    Got sorted anyway after much internet searching across various forums
    Jun 18 2010
    East of Cincinnati
    I've had problems keeping one lit.
    May 29 2010
    2004 Audi S4, 2008 Audi RS4 Ti
    Phildelphia / Auckland
    You only need one per side. The primary sensors need to stay where they are so it can trim the fuel mixture. If you simulate a false lean, it'll try to compensate by adding more fuel and may cause undesirable results.
    You only want to move the secondary sensors away from the exhaust stream.
    Nov 21 2015
    Galway, Ireland
    Only removing pre cats (cutting out and replacing with straight pipe)
    Same applies ?
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 04 2014
    2009 Gray A3
    California
    Can you guys add the lambda parts you purchased, as I will need to order mine online and mailed to me. Thanks
    Sent from my SM-G920F using Tapatalk
