Yes, appears to be thermostat as it was fluctuating as I drove it in.
They said I had the water pump replaced and because of that, they extended the warranty to 5 yrs, 100k miles. Now I am just passed 5 years they said. Always works out like that, huh?!
Should I try to negotiate them to cover the thermastat or part of it? Anyone had luck with that? Considering I'm just a few months past 5 yrs and well under 100k?
$2000? Are you serious? I was anticipating $350-400 for the 75k service... I even have this maintenance list I think I got from this site:
75K Maintenance
Parts:
(1) Engine Oil Filter (06E115562A) - $28.00
(1) Plug with Seal/O-Ring (N 0138157) - $1.63
(6.9) Synthetic Engine Oil (Quarts) (ZVW352540SBDSP) - $44.68
(1) Dust/Pollen Filter (8K0819439A) - $54.75
Total parts: $129.05
Labor
Engine Oil - change oil and replace filter
Service Reminder Display - reset
Dust and Pollen Filter - replace
Cooling System - check level, add if necessary
Exhaust System - check for damage, leaks
Engine On Board Diagnostics - check fault memory
Engine Compartment - check for leaks
Battery - check electrolyte level and add if necessary
Lights - check all lights, check headlight adjustment
Wiper/Washer/Headlight Washer - check adjustment and function, add
Wiper Arm Pivot Points - lubricate
Tires and Spare - check for wear and damage, check pressure
Brake System - check for damage, leaks, pad thickness, fluid level
Transmission and final drive - check for leaks
Power Steering Fluid - check, add if necessary
Drive Shaft Boots - check
Doors - lubricate door hinge mechanisms
Ribbed V Belt - check condition
Underbody - check for damage and leaks
Road Test - check
Total labor: $192.00
Shop Supplies: $9.60
Total: $330.65 + tax
