Results 1 to 29 of 29
    Nov 09 2007
    Illinois
    C5 A6 help please
    Hey I have a 2000 C5 A6 that needs work done. I have to replace water pump and heater core and trying not to spend a ton of money on parts. I'm trying to fix the car so I can drive it for a couple months while I try to sell it. I would sell it how it is but I don't think I would get any more than $1500 tops. I've put a lot of money and time into my baby and would like my help I can get. I plan on doing it myself bc a shop would easily charge me over $1500. I found own heater core for $300 and pump for $300. Ecstuning is looking a little pricey right now 😕 Anyone have any a6 they are parting out?!?! Helpppp please
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Gonna need to pull dash to replace heater core. Try to flush it with boiling water or crc first, or do you have a coolant leak and its too late? Nothing in these cars is cheap, will be hard to fix and get your money back but you never know.
    Nov 09 2007
    Illinois
    My water pump has been leaking for awhile. And while it was leaking I tried to bring it to a shop. On the way there the heater core blew and just ruined my day even more.
    Nov 09 2007
    Illinois
    I'm aware of all the water in my car I vacuumed out. Was trying to find help finding the parts I'll need and maybe if anyone is in the Chicagoland area they could help me with some pointers/special tools I might need? I'll make it worth your time if you can please help me out. Happy holidays everyone
    Sep 16 2010
    Central Wash
    That heater core project is insane. No matter how good you are or how much knowledge you have it's a huge job. The entire dash has to come out. All of it. Many shops charge 12-16 hours for heater core R&R- typically 8 hours minimum. I've never done one, and would probably crash my car straight into a wall before bothering. Not because I can't do it or it's too big of a project- but more because I'd be so fucking angry that fixing a pretty simple part requires so much work.
    I don't know which one I'd do first; water pump or heater core. Water pump might be easier, but it's dirtier. Can't drive if the water pump goes out though.
    Aug 04 2009
    Glen Ellyn, IL
    What engine?
    In Chicago area (Glen Ellyn) might be able to help you out. Have a heated garage.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Nov 09 2007
    Illinois
    2.7t 6spd. I would love any help I could get. I would love to use your heated garage but I cannot drive her anywhere...I'm in such a shitty situation...
    Jun 10 2013
    United States
    Replace the water pump and bypass the heater core so you can drive the car.
    You can fine quality parts at rockauto.com. I would use a gates water pump. What engine do you have?
    Nov 09 2007
    Illinois
    The water pump is only like $50 how is that possible. And I will do the heater core bypass. Any diy on the heater core bypass?
    Nov 09 2007
    Illinois
    2.7liter v6 awd
    Jun 10 2013
    United States
    OE parts can be very overpriced.
    Many aftermarket parts can be had for cheap but of are low quality.
    Gates is a high quality OE supplier and aftermarket supplier.
    The heater hose is 5/8" Get a 5/8" male male hose adapter from home depot. Disconnect the hose at the core (behind the battery) and connect them together.
    Nov 09 2007
    Illinois
    Wow I love you guys. Thank you so much for all the help. I'm ordering the gates water pump today!
    Nov 09 2007
    Illinois
    Which belt would you recommend. The Bando standard replacement one?
    Feb 23 2015
    2016 Q5 3.0T S Line, 2014 Q5 2.0, 2001 Cabrio GLX
    New Jersey
    Quote Originally Posted by rollerton View Post
    There is a posting on the AudiWorld site , C5 Forum, called "Heater Core replacement". With the procedure to replace the heater core without removing the dash. There is a video posted as well. Several posters have said it can be done by simply removing the lower driver side panel and sliding it out. Check it out. It absolutely looks possible on the C5..
    Good luck.
    Feb 23 2015
    New Jersey
    Check this out before you start ripping into your dashboard!
    http://www.audiworld.com/forums/a6-s...ement-2892747/
    Nov 09 2007
    Illinois
    Yesssss this just gets better and better. Much love everyone!!!
    Veteran Member Four Rings Yesmar's Avatar
    May 15 2009
    couple 2.7t's, and a tacoma
    Harrisburg, PA
    Jun 10 2013
    United States
    Quote Originally Posted by jonny91289 View Post
    What belt are you replacing!
    Nov 09 2007
    Illinois
    Would like to replace the serpentine belt that drives the water pump. My belt is getting shiny and some spots cracking
    Sep 30 2015
    just get a good oem grade belt. contitech or something similar. just did timing in my 2.7 c5 and the contitech timing belt was made in mexico (i know but better than china) and the drive belt, the one you want to replace, was made in germany, also contitech.
    change the belt before it breaks or starts slipping
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    The water pump is driven by the timing belt, not the serpentine belt on a 2.7T ....
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Jun 10 2013
    United States
    Quote Originally Posted by 02 A6 2.7T View Post
    I would do Dayco, Gates or Continental. All less than $20.
    Aug 04 2009
    Glen Ellyn, IL
    Good advice everyone.
    Still feel free to let me know if you need help OP. You can check with your insurance about a tow to my house if you need to. Working outside in Chicago winter sucks so bad.
    @fourings | Build
    Nov 09 2007
    Illinois
    708 548 1366 do I need to buy any special tools. I will not be replacing the timing belt. Just waterpump and heater core bypass for now to get her back running. Thanks everyone for all the help.
    Nov 09 2007
    Illinois
    And the contitech belt ;)
    Nov 09 2007
    Illinois
    Fuuuuuuck I think I should look into the tow to your place...would you mind texting me please?
    May 15 2009
    Harrisburg, PA
    Dude replace the thermostat and t belt if your replacing you wp
    Aug 04 2009
    Glen Ellyn, IL
    Will text you in a moment from my wife's phone, I'm in the middle of replacing mine. (Carlos, if you're reading this too PM me your number again when you respond to me so I can text you too)
    @fourings | Build
    Sep 30 2015
    ^^^^ good point.
