Results 1 to 10 of 10
    Nov 30 2015
    New Orleans
    2011 Audi A4 EPC and MIL light on...some shaking going on
    The car first started having issues accelerating- felt like a lag. The MIL light blinked and then eventually stayed on. I changed the spark plugs and ignition coils. When I started the car up, it shook more and the EPC light came on. I let the car start up and warm up and then the EPC light came on. Does anyone have any idea what is going on? Or what may have caused these issues?
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Have you scanned for codes?
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    check your maf sensor? do you have vag com to scan?
    2013 S5 Prestige
    STOCK. for now.....
    Gone: 2010 A4
    Mods: apikol rear diff mount / Zubehör rear diffuser / Unitronic HFC and DP / solo werks / awe boost gauge / carbonio APR intake
    Repairs done: Engine removed to complete repair Piston rings replaced (stage 1 and stage 2 oil consumption fix) / Wheel bearing(s)/hub(s) replaced / Crankshaft pulley/balancer replaced / Timing chain tensioner update
    Established Member Two Rings Mussa's Avatar
    Oct 31 2015
    Istanbul - Turkey
    maybe bad injectors or even cylinder heads. I'd prefer going to an Audi service.
    2011 A4 B8 2.0 TFSI Quattro S line S tronic // APR Stage 2 98 RON - OEM Dual Exhaust - OEM 3.0 TDI FMIC
    - USP HFC - RS4 Black Grille
    Nov 30 2015
    New Orleans
    I do not have a scanner that could read the codes for this vehicle. I went to an Autozone but the scanner could not read the Audi.
    Jul 17 2008
    Quote Originally Posted by olypoly83 View Post
    The Autozone scanners should be able to read our cars - you could also get an obd2 wifi/bluetooth dongle and use an app like dashcommand or carista to read fault codes. Even generic code readers should work. For us to help you we need the codes.
    Nov 30 2015
    New Orleans
    Thanks for the help guys. It's resolved.
    Jul 17 2008
    Care to share what the problem was?
    Jul 11 2015
    Washington
    Yes please on the problem I have the same issue sometimes!
    Jul 11 2015
    Washington
    Yes please on the solution rather. Thanks
