Okay, so background on me. I'm a competent mechanic until it comes to these German vehicles. I thought I could get away with getting one of these and just driving it and doing normal upkeep. I was wrong.
Recently I have gotten the "Low Oil Pressure" warning flashing across the tach when I come to a stoplight. This is an intermittent problem. I changed the Oil and used Castrol 5W-40 full synthetic (as always) from the sister VW shop the dealership I work at has in bulk. 4 quarts because I didn't change the filter. This stopped the light for about a weekend. Last night it flashed again as I got home from an hours drive, but only when I pulled into the spot. This morning it did the same, but I realized if I have it in neutral, this doesn't happen, probably because the RPMs are higher. ANY experience with this? Really trying not to condemn a pump, already have to replace a wheel bearing. The car just turned 77,000 miles.
Also, I have a p2279, p0507, p2187... I know these are all vacuum codes, LEAN. Looking into it, it looks like the switching valves assembly? Is all of this related? Again, I'm not a VW/Audi tech, I work on the easy Toyotas for a living.
If anyone could shed some light on this, it would be greatly appreciated.
Thanks,
Mac
